iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Feb 27, 2019 at 2:41 AM Post #1,201 of 2,153
Can someone please inform which cable can be used to feed a Chord Mojo (3.5mm coaxial).
i had this problem and found the only one that worked (for me) was a standard 3.5mm interconnect for a headphone amp (the one i have is from russ andrews - kimber cable - very short) and i did some research which basically stated that there would be no differnece in sound from a coax cable (given the short length)
hope this helps
d
Feb 27, 2019 at 5:22 AM Post #1,202 of 2,153
hope this helps
d
Thank you very much for the information and for the time you took to help! :beerchug:
Feb 27, 2019 at 12:49 PM Post #1,206 of 2,153
I love this dap. Great sound with my hifiman 400i planars. Only negative I have is that difficult to press on button through case
Feb 27, 2019 at 4:14 PM Post #1,208 of 2,153
keep me update, please.
So far so good! Received it at 80% battery life. Have used it for probably 3.5 hrs total now. Battery is still above half, haven't charged it yet. I also noticed that with this new battery, the screen has much better contrast and resolution, plus it gets brighter.
Feb 27, 2019 at 5:13 PM Post #1,209 of 2,153
Feb 27, 2019 at 5:37 PM Post #1,211 of 2,153
Hi folks,does this 400GB fit in the Dx120?
Thanks;Michele!
I have used 2 for 800gb, well less actual storage, but yes, it works fine and per the standard, it will take up to 2 TB and the 1TB cards are coming out very soon!
Feb 28, 2019 at 11:57 AM Post #1,214 of 2,153
hope this helps
d
Hey, could you send me a link to the one you bought? Many thanks
Feb 28, 2019 at 3:36 PM Post #1,215 of 2,153
Awesome!! that's great news, I can't go back to 1s now but someday I'll go back!
Thanks
