iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Discussion in 'Portable Source Gear' started by Paul - iBasso, Aug 31, 2018.
Tags:
68 69 70 71 72 73 74 75 76 77
79 80 81 82 83 84 85 86 87 88
  1. Lurker0
    silverfishla likes this.
  2. ericf
    I have a question about the Sound Mode settings. Do I have to restart the player after changing the sound mode or am I supposed to hear the mode immediately?
    I'm asking because I could hear absolutely no difference when I changed mode, listening through my Hifiman He-400i headphones. Do you hear any differences between the settings?
  3. Eddy Flycatcher
    I would like to know if future firmware upgrade will ever improve the readability, because the way it is at the moment about 80% of my collection is hardly visible...
  4. Jarous1
    I hear any little differences only if equalizer is OFF.
  5. Meelis
    Does latest firmware already have replay gain? My tracks have 27,25 dB loudness difference. Some of the track spectrograms are not even visible in linear scale (they don't even fit inside 1 pixel on 4k screen).
    When i'm washing dishes, i can not tune the volume down with wet hands when it starts deafening my eardrums.
    Nolbert0 likes this.
  6. Mhog55
    Anyone? I'm trying to decide between this, the Cayin N5iis, and the astell and kern ak70 mkii
  7. ericf
    Thanks for the reply. Mine is off so I guess I can't hear the differences.
  8. gmahler2u
    Hello.
    I'm in the family now, Just order dx120. I just got the bit opus1s, but I had to return it because they have the issue with the battery.
    I'm just hoping this dap great player to play with.
    Mhog55 likes this.
  9. Mhog55
    Please keep me posted! I'm in the same exact spot that you were. I look forward to hearing your sound and usability comparisons when you get it in your hands.
  10. gmahler2u
    I'll keep you post when I get the dap. it's coming next Thursday.
    JuanLuis91 likes this.
  11. Keko123
    This DAP play great sound but interface is like a cheap DAP. For example:
    1. Break line in middle of words, not between words.
    In artist screen:
    [​IMG]
    In settings sreen:
    [​IMG]
    2. Need estra padding right. Text go back of scroll bar
    [​IMG]
    3. Track information not legible. Is more important view cover album that track info?
    [​IMG]
    [​IMG]
    4. Gain level show different value in differents screens with same setting. For example, if i set low gain in settings screen, i view high gain in play screen
    Low Gain in settings screen
    [​IMG]
    High gain in play screen
    [​IMG]
    5. Traduction ON/OFF in EQ Setting is the other way. When EQ is OFF should be show ON button (Activar in Spanish) but show OFF button (Desactivar in Spanish). In English language is OK
    [​IMG]
    6. Translate to spanish is incorrect. Correct is:
    • Ordenar
    • Bucle
    • Aleatorio
    • Repetir
    [​IMG]
    Light - Man likes this.
  12. Keko123
    i add videos of my problem. Is this normal or fail?
    At the end of the video, jump two menu steps, when slide finder, select album ans track:
    When try scroll in albums screen, enter in album track list:
    More:
    Reinhold likes this.
  13. jamato8 Contributor
    The images are too big.
    I swipe up or down. If you put you finger on the selection, then it selects it. If the screen doesn't work well for you then exchange the DX120 or send it back. But I swipe and have no problem.
  14. serg7891
    Latest firmware. Still Cue does not work well. Pause between songs. Not all cue reads. When reading Cue of Russian titles, songs are highlighted in unknown languages.
  15. Paul - iBasso
    Thank you. I will let the software team know and they will work on this.
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
