iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Jan 27, 2019 at 12:21 PM Post #1,127 of 2,153
I think we're quite in agreement there.
Please try the current FW (always do a factory reset after updating). There is a current draw but it is a low draw.
iBasso Stay updated on iBasso at their sponsor profile on Head-Fi.
http://www.ibasso.com/ paul@ibasso.com
Jan 28, 2019 at 2:53 PM Post #1,130 of 2,153
Hello Paul.
I've tried the current firmware, here my initial observations:
1. There's an improvement: a) switch dx120 into dac mode, b) connect to a device - current draw is low. (I'm guessing dx120 is not charging internal battery)
2. If I keep it connected and switch dx120 into dap mode - usb current draw gets around 1000mah (on my device) - this is how it should be (dx120 should charge)
3. If I switch dx120 back into dac mode, after a while, current draw gets back to "low" (like in point 1)
Thanks for the good work!
ps.
Yes, I would still prefer to have it as an option in the settings, but I'm not planning to sell my dx120 any more.
Jan 28, 2019 at 6:27 PM Post #1,131 of 2,153
hey @Paul - iBasso
New firmware 2.3.53 has a critical problem.
When I select a file in "All Music",
the artwork and file information is wrong.
I mean the other artwork and information is showing.
Anyone has same problem as I do?
Hello @Paul - iBasso
please check this issue.
Play mode : Random
the artwork and information is wrong.
It happens on only random play.
Jan 28, 2019 at 6:34 PM Post #1,132 of 2,153
I have more issues:
1) Text break line in middle of word, not between words.
2) extra right padding in some screens will be ok.
Jan 28, 2019 at 6:41 PM Post #1,133 of 2,153
hey @Paul - iBasso
Yes I have seen that as well. Sometimes the screen is showing info and artwork for entirely different track and artist.
Jan 28, 2019 at 10:35 PM Post #1,134 of 2,153
If you change your mind, I might know a guy.
Though I'd still want to know the approximate battery drain per hour, but now I'm going to struggle to keep the Sony. Am a fan of the 4.4mm jack now, not going to lie. But it isn't absolutely essential.
Enjoy!
Jan 28, 2019 at 11:28 PM Post #1,135 of 2,153
I have more issues:
If you rescan does it still do this? Please email me at paul@ibasso.com with results. We are trying to duplicate this.
Jan 29, 2019 at 5:44 AM Post #1,138 of 2,153
Hi, i have a slight issue with the new firmware (lurker version) - when using artist mode and selecting an album and SHUFFLE -and then slecting the first track, the first track then repeats itself, this does not happen if any other track (than the first) is selected.
Feb 4, 2019 at 10:27 AM Post #1,140 of 2,153
I've been using the DX120 for 2 weeks now and its battery quick charging scenario has already damaged my lipo battery noticeably.
After the first four recharges - each lasting exactly 2 hours - the player ran for more than 14 hours in SE mode with my KZ AS10 inears.
The power bank never turned off after the recharge process is completed.
When i charged the player for the first time overnight (at least 7 hours connected to the power bank, the charge bar indicator needs 45 minutes to change from 100% to 99%.
Unfortunately the player only runs 7.5 hours in SE and 6.5 hours in balanced mode from that point on with the AS10.
I am also disappointed about the quality of the keys - they have different pressure points, the start/pause button has almost none.
Protected by the included cover, the DX120 can hardly be operated. (longing for the DX90 keys - they work perfectly from the first day on, also with my beloved silicone cover)
The Shanling m5s, which I bought for comparison, needs 3 hours of charging time, but it runs more than 17 hours in SE and 10.5 in balanced mode with the same KZ AS10 headphones.
Apparently, I will have to send the DX120 back to amazon.co.uk.
