iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Discussion in 'Portable Source Gear' started by Paul - iBasso, Aug 31, 2018.
Tags:
63 64 65 66 67 68 69 70 71 72
74 75 76 77 78 79 80 81 82 83
  1. jamato8 Contributor
    I have the DX120 and it will scan even a 400gb card pretty fast. It also picks up most all albums and there a few null, that need retagging. Maybe check your tagging and I would reload the firmware and then do a factory reset.
  2. Eddy Flycatcher
    All my tags have been checked and all files are checked in Foobar's Exact Audio Rip, I have reloaded the firmware 2 times already and ofcourse done several factory resets. I have just 1 null album and that is because I left off the artist on that one. I just finished scanning the 2 cards it took 1 hour!
  3. jamato8 Contributor
    How many files are there on the two cards?
  4. Eddy Flycatcher
    Card 1 holds 591 files = 196 Gb; Card 2 holds 640 files = 207 Gb. All files are ALAC, album cover art is 240x240 pixels.
  5. Eddy Flycatcher
    I have a question, I'm coming from a Fiio X5 (first gen.) and because I use it as a transport (coax out) the battery last a lot longer (not using the DAC or Amp) but that doesn't seem to make much difference on the iBasso...
  6. Photoman
    Do the dx120 have a clicking noise when turn on? Like a relay feature?
  7. Eddy Flycatcher
    Ther is a pop sometimes when starting a new album after I listened to one. Strange is when I look at the lights on my DAC they turn off after an album is finished, on the Fiio X% the lights remain on until I shut it off completely. After I have listened to an album the lights on the DAC go out and there is a faint crackling noise, not in between tracks.
  8. Caruryn
    Hey man long time,hope you're doing
    well,in Alaska if i remember correctly.Would you consider DX120 an upgrade to DX90,i'm assuming it has the bigger sounstage from what i'm reading but what about other sound aspects,like tonality,detail and bass.I think it would pair great with CA Atlas as it does with dx90 although the soundstage width could be better.
  9. gefellmics
    I'm really happy to read this, because I have exactly the same problem and getting very frustrated with this issue. Sometime I can power on the DX120 without no problems, but very often I cannot turn the DAP on at all. The backlight is switched on for few seconds and after this the unit gets powered off. Because of this issue the DX120 is still unusable for me.
    What about the Batch/Factory Tool that Paul recommended? Did that help you with the problem??
    I use firmware 2.2.42 and I have the problem is usually after loading the battery or otherwise when I powered it off over the night (for 6-8 hours).
    Any help is much appreciated!
  10. BonzerKeith
    Paul asked me to return it to iBasso, which I did, and they replaced it straight away. I have had the replacement a few months now, and have had no problems. superb DAP.
  11. Whitigir
    Lovely! Ibasso and Paul is unbeatable for after sale services and customer services
    Copland62 likes this.
  12. Paul - iBasso
    If this persists please contact me at paul@ibasso.com and I will get this corrected for you.
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
    Whitigir likes this.
  13. gefellmics
    Thanks a lot Paul...I will keep you informed.
    ....such a great customer service is really appreciated!
  14. Jarous1
    New firmware 2.3.53 :)
    1. Supports USB OTG audio output and supports up to DSD64 via DoP.
    2. Improved DXD support.
    3. Allows slide operation when the title, album name, or artist name are too long to be displayed all at once on the main screen.
    4. Improved the thumbnail icon display speed of the album view.
    5. Improved the "Added" sorting function of the All Music view.
    6. Rectified the bug that some special characters were displayed as bold.
    7. Allows adjustment of the line out volume.
    8. Improved the CUE support.
    9. Improved the display speed with a large library.
  15. vinhnc123
    Does anyone has problem with songs that have Japanese title? My Japanese songs scatter all over the song list which makes it impossible to find a specific song. No similar problem with the previous DAPs
