iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Discussion in 'Portable Source Gear' started by Paul - iBasso, Aug 31, 2018.
Tags:
101 102 103 104 105 106 107 108 109 110
112 113 114 115 116 117 118 119 120 121
  1. Rattle
    Yes I know that thanks.
  2. claudy
    I'm not familiar with WeTransfer apps ( i can't figure it out to send the files ) , can you give me an e-mail or Gdrive account paul?
  3. Paul - iBasso
    Here it is and it is free. It works best for us: https://wetransfer.com/
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
  4. claudy
    album sent Paul.
  5. vas-tomsk
    In firmware 2.6.94, gapless still does not work with FLAC+CUE and so on. Paul, mission impossible?
    Rattle likes this.
  6. Rattle
    Kind of crazy this is an issue. Seems like it would be basic functionality. Regardless I've been splitting live albums and ones without silence between tracks. Kind of sucks though...
  7. ikkentobi
    There is one feature in the DX120 software which I am really missing (and my venerable FiiO X3 1st gen has it). To understand it you must know that I have a large collection of tracks which are either 2 or 3 hours long. These are recordings of some radio broadcasts.
    Now, to "fast forward" to, for example, minute 120 of a 180 minute recording will require a lot of endurance - because the fast forward is not accelerating. Try it yourself, it is a real pain.
    Ideally after some time of pressing, the FF should accelerate, and then gain more speed if it is pressed continuously.
    ibasso - is there some chance you can implement this useful feature?
  8. crabdog
    You can tap the touchscreen to shuttle on tracks!
    ikkentobi likes this.
  9. ikkentobi
    Thank you for suggesting that. It seems I completely overlooked this possibility, it works very good.
    Perhaps, coming from a player without touch display, I focused too much on the button control...
  10. crabdog
    You're not alone, it took me a while to find that too. :wink:
  11. Rattle
    So with latest firmware, if I select through artist and play and try to play an album, instead of going to the next song in the album it goes to another album. I have to browse through albums for it to not do this. Tried all settings to no avail. Installed previous firmware and everything is back to normal... anyone else ?
  12. vas-tomsk
    I also had this after installing 2.6.94 firmware. I removed both memory cards and reset from the player menu. Try to do so.
  13. trivium911
    This is from using artist/album selection and going back and forth to folder/directory view. Selecting from album view for example only plays one song from that artist or album Instead of replacing what was in the now playing screen and playing all of them. It seems the only way to fully replace and play the whole album for example is to use directory/folder view. The previous firmware does not do this so I rolled back.
    I'll try removing both cards and resetting though...never did try both of those.
  14. claudy
    well it seems works like a charm, thanks for the tips ya...
    and also before try this methode, several times i played a tracks it sounds like fast forward 2x or 3x. hope this method fix all the bugs
  15. claudy
    try vas-tomsk method, it works with mine.. .
