iBasso DX120 pure DAP player. Balanced, single ended, line out and 2 micro SD slots. FW 2.9.21 now out!
Discussion in 'Portable Source Gear' started by Paul - iBasso, Aug 31, 2018.
Tags:
100 101 102 103 104 105 106 107 108 109
111 112 113 114 115 116 117 118 119 120
  1. Rattle
    Yeah I had a fiio that would always have issues unless browsing directly through directory. This dx120 is a breath of fresh air in comparison.
  2. trivium911
    Haha exactly! Same here. I have the X5ii and X3ii and use to have the x1
  3. tokyodan
    Hi,
    Where can I get more info on this lurker / fidelizer firmware?
  4. Rattle
    Lurker0 likes this.
  5. claudy
    after upgrade FW to their latest does anyone have an issue with the librarys? it seems my albums are some get mixed up & some of them even doesn't show, have to go to directory, been scanning about 5 times and still the same.
  6. Paul - iBasso
    Does the scan complete?
    iBasso Stay updated on iBasso at their sponsor page on Head-Fi.
    http://www.ibasso.com/
  7. claudy
    yes paul, i notice many of the files are in aiff format, but not really sure 100% tho. as an example i have several Roxette album that i ripped from my cd's, and the crash boom bang album just show 1 song, as other example matchbox twenty 1 have 3 album that also i ripped from my cd's the album just show 1 and the rest of the others album are in there.
  8. Paul - iBasso
    I am not sure what your last sentence means. The scan completes but not everything in the albums shows up?
  9. claudy
    yes, it won't show the 3 whole album, it just show 1 album, but inside of it lay all the tracks from other unshow album. and also it suddenly skip tracks, i was listening to kelly clarkson songs and the next song change to marshmello, this often happens.
  10. claudy
    this one is when i search from artis name
    20190810_234359.jpg and this is from the directory.
    see the problem paul? also now everytime i played 1 song and the next song play is by marshmello. yes i did the factory reset twice and nothing good happened.
    maybe tomorrow i roll back the FW.
    pardon my english tho.
  11. Paul - iBasso
    Can you send the albums that are doing this using WeTransfer to service@ibasso.com? We can then find out what the issue is.
  12. Rattle
    Any of you guys using faster micro sd cards, what read and write speeds are you hitting with DX120 hooked up to a pc transferring files? I think I got a fake card...
  13. mbwilson111
    Unless I am just adding an album or two to one of my daps, I usually find it better to put the card in a card reader when using the PC to transfer files.
  14. Rattle
    I don't have a card reader trying to see what the dap maxes out at.
  15. mbwilson111
    A card reader is inexpensive and is a good thing to own.
