IBasso Audio IT03
54 55 56 57 58 59 60 61 62 63
65 66 67 68 69 70 71 72 73 74
  1. nmatheis Contributor
    Nope, no Reference 8 cable here, my man. I found IT03 responded better to some sources than others with respect to taming the bass and bringing the mids forward, so if you haven't anyway I'd recommend playing around with different amps, DAPs, etc...
  2. Jackpot77
    It has very good synergy with the new Hifiman Supermini - I think the IT03 likes a source with a decent amount of power.
    Waiting on a 3.5 to 2.5 balanced adapter to see what the IT03 sounds like balanced (the Supermini is my only balanced source) - hopefully it will turn up with a set of VE Monk Plus in time for me to include the results in the impressions I'm putting off writing! :wink:
  3. Jackpot77
    Not a major believer or disbeliever in burn in, but I have found the bass settling down in terms of presence and quantity as my set approach the 100hrs mark. Really liking the sun bass and how it adds substance to some of my favourite rock tracks.
  4. nmatheis Contributor
    I measured before and after ~200hr burn in with no measurable change. Not that there couldn't be some audible changes in big I'm not picking up with measurements. Just thought I'd let people know I did remeasure but didn't pick up any changes.
  5. AndrewPL
    I have that headphones and I can't hear any difference in sounding after 150h of so called burn-in, they don't want to sound differently after burn-in, maybe mine are defective? :wink:
  6. Jackpot77
    Maybe it's just brain burn in, but the bassiness of the signature has receded in my head, leaving them sounding a little more balanced, but still with plenty of bass impact. I Have been listening about as much as I have been "burning" them, duo could easily just be getting used to the tuning.
    Either way, the sound is very enjoyable - not going to worry too much slot working out why! :wink:
  7. Jackpot77
    Reading this thread inspired me to pop the IT03s in for a quick listen. One Jack Savoretti album and a few All-American Rejects tracks later and I've just noticed what I've been doing. May as well settle in for the night! :wink:
    Richsvt likes this.
  8. drakhen
    So I'm interested in picking up the IT03 as my next universal IEM. I have read through this thread, but had a few questions:
    1) I'm a little unclear about the sound signature. Is it energetic rather than smooth? Also, it is not a dark sounding IEM, correct? Is it comparable to any other IEMs?
    2) How is the isolation? Is it comparable to Shure and Westone IEMs?
    3) I gather the IT03 doesn't come with any foam tips? I assume you can use Comply, but how do they affect the sound (if at all)?
    Thanks in advance.
  9. omastic
    1. It's energetic AND smooth. May be not the smoothest around but definitely one of the smoothest TWFK based set I have ever heard. I believe its safe to say the IT03 is quite smooth for the amount of treble on show. Signature is just a touch V shaped with good mid presence (IT03 will never be classified having thick lush mids though)
    2. Isolation is slightly less than a deep fitting Shure or Westone with foam tip. In general isolation is more than adequate for commuting.
    3. No foam tips included. I don't have comply but did try using some generic foam tips. It reduces the treble energy and brings the mid range a hair forward in the mix. For my tastes the wide bore and short stem stock silicon tip sound better.
  10. vwong99
    Had got this set about 2 weeks, and have burned in almost 100 hours (i think) with the stock cable.
    As of now, i heard the coherence and sound signature has tamed down. The sound spectrum has been smoother and the bass were in place now.
    Yes, the high/peak notes sounded quite sharp earlier on. But after some time, it was smooth and fluid.
    Trust it will get better after the 150 hours mark.
  11. borjok536
    How does the IT03 sound compared to Fidue A83? Im planning to replace my A83 since I lost it 2 weeks ago. I like the sound of Fidue A83 but the mids are a bit thin, does the IT03 has that similarity when it comes to Mids?
  12. HiFiChris Contributor
    Here you go: http://www.head-fi.org/products/ibasso-it03/reviews/17101
    Quote from my review:
    To me it sounds like the IT03 could be a match for you, based on your description of the Fidue's mids.
  13. notfitforpublic
    Got a set coming in to pitch against my Noble 3's. Pretty excited to see how these turn out, N3U's aren't really my cup of tea.
    Did a quick search and couldn't find any mention of the pairing with the X3ii. Any of you good folks have both and comment? Do they have a hiss with the X3ii?
  14. H20Fidelity Contributor
    I've been listening to IT03 for a few hours now.
    I'm quite pleased with the sound, I agree with those saying its a nice earphone. Great coherency, open sounding. I've also noticed the bass is quite tight and rather detailed. So far I find them rather balanced across the bass and treble, maybe a little less on the highs compared to the rest of the frequency range. I've already asked myself if I could live with IT03 if I somehow lost my other higher teir earphones, I believe I could, yes. It would probably be my first alternative from what I've heard this year.
    Will chime in further when we get to know each other.
  15. borjok536
