GabrielBosky
Hello to everybody and, particularly who will be so patient to read and give me some tips!
As I wrote in my presentation, I'm new in audiophile world, and I arrived here casually: I was guitar player for a long time and I bought a pair of Beyerdynamic DT990pro 250 for studying sessions and it don't sound too bad with a simple creative xfi fatal1ty soundcard with "platinum series" front connectors.
Obviously the headphones sounds better with a an hold kenwood hi fi.
Now I transferred from my town to my actual base: new work, new life. No time for guitar but more time to listen music but I decided to invest some money in something new (I leave the DT990 in my old home so i have something new to lesten well).
SO
I bought a pair of Sennheiser HD650 after some other ""headphones"" and the decision to change my soundcard.
So I bought the Creative X7 limited (at good price) and early i had to buy an headphone amplifier: my decision was the Valhalla 2 from Schiit!
My best choose ever... Not for my wallet for shure! I discovered a new world and I started to pretend more from what I listen and the sound arrive to me.
I like, Valhalla with HD 650 but I have the impression they are very limited with my soundcard.
WHERE IS THE POINT?
I hear as the music is little tight, hold in little space, specially if I don't use the direct mode.
With direct mode the sound seems to clear and certainly more natural, i loose some bass power but i gain in their definition!
What about this card as DAC? I chose it for is 127db SNR and its 24/192 asynchronous system but maybe this was a bad choose! I am in the return period so I want your advice: I think to buy the Schiit Gungnir Multibit as DAC...
In this way I hope to gain in sound spatiality and instruments separation. Better quality... Can be this the right way?!
In this case maybe the X7 will comes useless. So maybe I can return it.
I saw also the GUSTARD DAC X20 Pro Super Ultimate 2 a little bit less expensive and with some good specifics on his side!
I have also the necessity to have a way to use guitar processors programs and the creative audio helps!
So I really need new DAC? How mutch i can improve my sound with gungnir? I cam resend the X7 back?
Any other (not used) DACs to consider? (Budget from 500 to 1500€, obviously something that matches with Valhalla 2 and Senn)
Thank you for your patience, I hope I didn't bored anyone
Waiting for your reply
SO
WHERE IS THE POINT?
