I will answer to you and maybe it will helps to the post writer.
From this picture I can see that you are unprofessional soldering!
1st- Your solder may cheap one, chines and not quality one.
2nd- as shown in the picture: the soldering looks like COLD SOLDERING, in other words is a mistake!
Cold solder have very low conductivity, so... until you will clean it i think that the Resistor-metter cant detect through it.
3rd- you are put to much solder when there is no wires on it at all
4th- I cant see any metal conduct parts of the driver
your solder looks like a big mess that covered the central coil ends, that connected to the main driver coil
5th- the green coating that isulate and make the soldering right is missing on the plate. your soldering looks really bad!
I'm sorry but you cant fix that!, if you create such a mess, I don't think that you can fix this.
If you want to see how to fix, see this one
Hi,
I'm the happy owner of an Alessandro MS1(000), sounded great, even if having tremendous odds and no more real amp to drive it sadly, and it did sing until the cable commited suicide.
And here I am, bought the cheapest cable on zBay as finding suitable wire and Y splitter is a challenge. Grado's blue wires for ground, then white and red. Solder the chinise thing. Copper is copper right?
And now I can't bear the sound. Muddy, voices are like cheap cardboard speakers.
So I'm asking for first hand experiences,
Can one fry the drivers when soldering?
Can the cable impact the sound that much? I admint my rusty blackened OEM wires are 0.2ohm when that shiny chinese cable is 0.7, maybe even add capacitance...
Crap! I want my Grado back!
Matthieu
First if you solder it right and strip it coating right
try to use another cable than the Y splited
like this two but try to fing more quality one
https://www.ebay.com/itm/Repair-Aud...255604?hash=item3d582b9274:g:vQAAAOSwPOhadCwv
https://www.ebay.com/itm/II-Black-R...4?hash=item2cad66d11a:g:zzoAAOSw9eVXUShK#rwid
