Speedbird
- Feb 11, 2010
I had my Sennheiser HD555s plugged in on my front headphones port and when I was moving around in my chair, I accidentally bent the 3.5mm plug. I bent it back but now sound is coming out on the right side only
I tried the back port and it works fine so the port is definitely damaged. Now I need a splitter to connect both my speakers/headphones to the back of my sound card, a HT Omega Claro Plus+.
I've been looking on Monoprice to no avail so now its Amazon. I found Amazon.com: Belkin F8V234-WHT-APL Headphone Splitter: Electronics these and I'm wondering if they will lower sound quality? Are there any better quality ones than these?
And just in case, the HD555s need some kind of converter to make it fit 3.5mm. The wire for the 3.5mm is bent and just in case, I'm looking for a replacement for it. Will these Amazon.com: Grado Mini Adaptor Cable - 1/4 Inch to 1/8 Inch Plug: Musical Instruments suffice or am I looking at the wrong plug/adapter/whatever?
Although I can't seem to find any, I would like to buy these off Monoprice but any other website will be fine.
Thanks in advance.
Thanks in advance.
