Szadzik
- Dec 19, 2009
Hi,
Zagg.com give you a lifetime warranty for the shield. You break it, you report it and get a new one for free as long as you return the old one. If you do not return the old one, only a small charge will be made towards the replacement.
It feels a bit rubbery, not hard like plastic or glass and feels very nice. Nicer than the Brando screen protector on my phone and I really value Brando for their screen protector quality.
I have it on both the back and front. And it stopped the problem with fingerprints all over the player too.
As for taking it off, there definitely is a way to do that, you would need to check Zagg.com as they should have a manual or something for that.
The player looks really sexy with this skin, is very well protected, and what is very important does not have fingerprints all over it
Originally Posted by FortisFlyer75 /img/forum/go_quote.gif What is the life expectancy of a invisible shield? Is it the same or more as a normal type of screen protector would you say? This is the stuff that you sort of paste a sheet to the back and front of your player? Also can it be taken off easily if for any reason you do not want it on there anymore? |
Hi,
