amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
They are rated to source or sink 20mA.
When the amp is idling, the quiescent current goes from the positive rail to the negative rail, not through the TLE2426. So it' not going to fry. On the other hand, when you have a low-Z can connected and have the volume turned up, then the ground return current will go through the TLE2426 if it isn't buffered externally. Fortunately, what we're talking about here is music (bursts of current rather than a steady state current), so it would be much easier on the TLE. No question, though, that letting the TLE2426 bear the full return current is not the best thing to do, and this is the primary reason why the cmoy is basically a toy, and is what differentiates between, say, the MINT and the Pimeta.
Originally Posted by doctorkelsey I think (correct me if I am wrong) the TLEs are actually rated at 30mA maybe even 20mA. |
my A47 with two opa2134s gain 2 at full volume into my grado sr-80s sucks about 45-50 mA and a no load current of 20mA. So, I think eventually if I didn't have a buffer, I would fry a TLE. Now with a cmoy, much less current is needed, so I can see maybe using a single unbuffered TLE for that- but it still isn't ideal current output. |
