schaaf
- Mar 18, 2005
Ok here is my situation.
I have been looking around here for a couple of months, and I seem to get nowhere. I have recently been allowed to up my budget from its lower price, and I have started looking all over again... It gets insane, what with all the choices and cables and amps and phones and places to look and prices and everything!
I am looking for an amp, dac, and headphones.
I am not looking to spend more than 1000.00
My current set up is iMac G4 > Senn. HD 555.
The source cannot change. That is what I have. All my music is either 320kbps or Apple Lossless. I am using iTunes.
I listen to a TON of Dave Matthews/Acoustic. I also listen to rock/alternative like Chevelle, Incubus and others of that type. I like bass, but in an accurate way. Not overblown boomy bass.
I want soundstage. I want to be in the crowd. I dont want to be up in the face of the band. (How I currently feel.)
I want clear precise highs, nice mids, and a lowrange that is there, but not overpowering.
I listen for hours at a time, so something that is going to be comfortable to wear for extended periods of time.
I don't have the option to audition much of anything at all. I have looked/checked around and I dont have to many options for a local buy.
I have decided that I like the looks of the Meier corda Cantate system, as it has both the amp and the DAC, and seems to get fairly good reviews.
I am unsure what Headphone to pair with that. I am either looking at the K701s, DT 880s or the DT990s. (I have thought about the Senn. HD650s and such, but Im not sure I like the "on the stage" sound I currently have with my Senn 555s.) I have tried on some Ultrasones, and found them uncomfortable. They sit around your ear, but leave no room inside for it.
I am, of course, open to other suggestions, but please keep in mind my budget, and my preference for soundstage. I have looked at some tube amps, but I would then have to buy a seperate DAC and that would reduce my overall budget.
Anyone have any suggestions about this set up?
thanks!
schaaf.
thanks!
schaaf.
