HURRY!!! Pls help me to CHOOSE!!! HD218i or CX300?
Aug 14, 2014 at 2:16 AM Thread Starter Post #1 of 17
ivanlau1999
Hi, since there is a chance that I can get either one of them for 65% off, I would like to get one of them for portable use. It doesn't matter if it was in ear or over ear, all I want is a strong bass, decent mid and a decent high. I mostly listen to epic music and some pop. And the power supply will be my iPhone 5 and the 2nd generation of iPod touch.
So which one will suit me better?
Sennheiser HD218i or
Sennheiser CX300
BTW, portable is not a problem for me.
Aug 14, 2014 at 4:41 AM Post #2 of 17
I think you'll be happier with the HD218i out of the two, the CX300's bass depends more on a good fit being an in-ear, and they are a little less clear.
Aug 14, 2014 at 6:22 AM Post #3 of 17
Thank you for your advise, now there is one more option to choose : the sennheiser MM50
Any other opinion?
Aug 14, 2014 at 8:43 AM Post #4 of 17
The MM50 is better than the CX300 but you will still need a good seal to benefit from the bass of the MM50. If you've had in-ear headphones before and they fitted well, the MM50 could be an option.
Aug 14, 2014 at 10:45 AM Post #5 of 17
Oh god the CX300 is horrible. Fake CX300's sound about the same as real CX300's I just replied to another thread asking a similar question. What's your budget? Canal-phone, IEM, or earphone?
Aug 14, 2014 at 12:23 PM Post #6 of 17
I have a super low budget.... Just $40 CAD
Aug 14, 2014 at 4:20 PM Post #7 of 17
I am thinking.... Is $37.49 worth for a HD218i......
Aug 15, 2014 at 2:12 AM Post #9 of 17
Now there is a bit more option for me.....
The following is in CAD
So the headphone/earphone I can get is:
Sennheiser HD 218i for $37.49
Sennheiser CX 300 for $39.99
Sennheiser MM 50 for $34.99
Sennheiser PX 200 for $64.99
Beyerdynamic DTX 710 for $44.99
Beyerdynamic DTX 71IE for $59.99
Logitech UE4000 on ear headphones with noise isolating for $39.99
Shure SE112-GR for $59.99
I am not so interested in sony because they usually have kind of overwhelming base for me.
Thank you very much!!!
Aug 15, 2014 at 6:15 AM Post #11 of 17
Please I need a answer since I will be purchasing the headphone tomorrow because it is the last day of sale.
Aug 15, 2014 at 12:49 PM Post #12 of 17
Shure SE115-GR, though its only $49 in the states. PX200 is also a good option, but most people prefer the PX100 (a classic, truly good). Is the PX200-II or PX200 (same with the 100's, is it PX100-II or PX100)? The original version is better...
Aug 15, 2014 at 2:29 PM Post #14 of 17
Great it was PX-200-ii
So now priority is Shure SE115-GR and PX200-ii
Aug 15, 2014 at 2:31 PM Post #15 of 17
Anyone got some opinion on the Beyerdynamic DTX 710?
I can't find much review about it.
