How well does the 1 piece BestSkinsEver settle on the 1G Nano click wheel?
Dec 24, 2006 at 5:54 PM Post #2 of 4
I don't know about the nano but I own a sansa e260 and I bought a BSE skin around 3-4 weeks ago. I receieved it pretty quickly and the installation was pretty smooth.
You will definitely need to follow the instructions though, if not you will have air bubbles all over the place.
On the click wheel, I believe that would be no problem. Since the click wheel is basically inside the iPod as in the same surface than you can just lay it over and use it freely. It's touch sensitive so, no problem.
Dec 24, 2006 at 6:16 PM Post #3 of 4
I dont have a Ipod, i have a ZVM. However, i have the BSE on it right now. After a few days any little bubbles will make their way out. As long as you pushed the bubble to the closest corner/edge you should be ok.
Now, i removed my BSE off my touch for 1 reason. IT SUCKS when you fingers are wet...not even wet, when you hands are clammy or you grab a nice cold drink, if you touch the BSE, your fingers will kinda skip on the skin. It almost feels tacky. I wouldnt use the click wheel part unless you ready to deal with that.
Just my personal opinion, people on the ZVM forums voted on how many people actually use the skin on the touch pad, i think it was like 85% of people dont use it for the reason mention above.
Again, totally up to you.
Dec 25, 2006 at 6:19 AM Post #4 of 4
That is a good point HighLife but, going in a circle and up and down are different feeling
. If you go in a circle you fingers won't skip, I think. Haha.
