How to properly charge and prolong the life of Lithium batteries
Apr 12, 2008 at 8:11 PM Post #31 of 47
Chri5peed
Originally Posted by athenaesword /img/forum/go_quote.gif
so the usb2.0 runs at a higher voltage than what the Li+ battery is supposed to charge at.. issit not advisable then to charge via usb but use a 4.2V ac charger? or will it charge at 4.2V all the same.
Reply to olden question, but relevant.
Batteries will just suck what they need. Current is involved too, but that muddies the waters and you don't need to know...
Jun 1, 2008 at 1:28 AM Post #32 of 47
0roo0roo
Originally Posted by Chri5peed /img/forum/go_quote.gif
I knew most of that being an electrician, but certainly very handy. Proper care for my Zen Touch battery has meant its kept its capacity for nearly a year, it nearly lasted all the time I was away on vacation last week, well over 20 hours.
Also its important to know that Li-Ion batteries charge at 4.2Volts per cell and USB2 ports run at 5Volts. So in fact DAPs which charge through the USB port are getting the same level of charge as using the mains.
Also, I didn't know, but USB2 ports stay energised as long as your PC is plugged in, but it doesn't need to be turned on. Li-Ion batteries can't be overcharged so its okay to leave your DAP connected to the USB constantly.
i think they can be over charged, its just that the controller will just stop it from happening.
just keep the thing relatively full and it'll be fine. mp3 players are so low drain they are pretty gentle on their batteries.
Jun 11, 2008 at 10:39 PM Post #33 of 47
Tinderbox (UK)
Hi.
First post.
If anybody's interested 3.85 volts equates to 40% charge in a li-ion cell.
A number of different player will show you the battery voltage in the service menu.
Regards
John.
Jul 14, 2008 at 3:04 PM Post #35 of 47
Stereodude
Originally Posted by acp6s /img/forum/go_quote.gif
be sure not to recharge when relatively full, best way is to drain then recharge then
Not for any Li-Ion chemistry battery. They are best charged early and charged often.
NiMH should be discharged completely occasionally, but isn't needed every time.
Aug 5, 2008 at 7:33 AM Post #36 of 47
grayeyes
good info, thanks
Oct 31, 2008 at 5:04 AM Post #37 of 47
noahlapuz
simple don't recharge it when its not completely drained
Feb 12, 2009 at 4:11 AM Post #41 of 47
salsala
I think the most impt step is always to charge superlong on the first charge right? I always charge like 10 hours for the very first charge even if it shows that the batt is full. I also heard that once in a while you shld fully drain the battery and recharge again.
Aug 22, 2009 at 2:58 PM Post #43 of 47
uday1583
Very informative links, i have read them completely and got some good inputs to improve the battery life. Thankyou for the links, if I misuse or abuse my battery, the most it's going to cost is £25 for a replacement a couple of months down the line. Thanks
Mar 14, 2010 at 6:47 PM Post #44 of 47
yliu
Originally Posted by austonia /img/forum/go_quote.gif
good information for HD-MP3 player owners:
How to prolong lithium-based batteries
Charging lithium-ion batteries
So it basically tells you to keep the battery cool when not used, and to charge it frequently, and don't wait for to battery to run out fully and then charge it.
