In that case Rockbox might offer you features like a usable EQ and crossfeed for soundstage, if your ipod is rockboxable that is
edit: in response to your post before mine, unless you right now use EQs on your ipod i doubt rockbox will fix your distorted bass problem, maybe an amp is the way to go afterall
You may want to try a cmoy portable amp. They work great ND are very economical. Here is a link to where I bought mine and you can find them all over ebay.
Using them on something better than an iPod Classic would be a good start. A Cowon D2, for example. Lacking that, use a headphone amp that uses the base connection on the iPod instead of the substandard headphone output.
