cachedbrown
Ok this is going to be a bit weird. I have a vinyl player that I connect to my Strdh 190 receiver to use as a pre amp. I then use RCA connectors to connect them to my speaker. I just ordered the DCA E3 and wanted to see if I could listen to my vinyl player through them instead of my speakers. There’s a 1/4” headphone port on the receiver, I don’t know how many ohms it is but from what I read online typically receivers have really high ohms. From what I understand this means unless my headphones also have really high resistance(which they don’t) I will hear a lot of distortion. Now I did also get a topping G5 to use as a dac/amp for my headphones. It has a 3.5 mm LINE in port. Could I in theory get a 3.5mm to 1/4inch connector cable and attach my receiver to my topping g5 in order to listen to my vinyl player? I’m not sure if that’s how it works, any help would be appreciated.
