Samueru Sama
- Dec 5, 2014
Very useful information, thank you for that. My onboard audio from both laptop and pc have very bad hiss. What would cause that?
So the multimeter would produce a perfectly objective datum and, if my volume is even slightly higher on one it will give the impression of greater dynamic range over the other. Am I correct in my understanding?
I doubt there would be too much of a difference between votages with S6 Edge + and Edge, I would think there would be a difference between EU and the rest of the world Samsung phones in general because of EU phones being volume capped.
Do you hear hiss with the HD650? Hiss is usually an issue with sensitive headphones, it really needs to be terrible for it to be perceptible in headphones like the HD650, If you hear it with the 650s that would mean that noise is higher than 65 uVrms. What do you mean with greater dynamic range?
Huge amounts of noise can be due to groundloops (which are common issues on computers), also a bad decoupling from the power supply and/or lack of RF filters, also computers suffer from the fact that there's non that I'm aware of that has analog volume control, all of then adjust volume by reducing the signal amplitude at the DAC, there's a problem with that, it means that the output stage is constantly working at "100%" with all the noise from the DAC and johnson noise.
Lets say that the DAC+Lp filter max outputs 1 Vrms and has a fixed noise of 30 uVrms, that's tons of hiss with sensitive IEM's. However that gives a DR of 90 dB, you wont hear it at all if the volume is at max (1 Vrms) but obviously you can't do that with sensitive headphones, it will fry them if the thing is actually able to output 1 Vrms into low impedance loads, and also you will go deaf, so you have to reduce the amplitude down to 0.1 Vrms.
However since there's no analog volume control, the fixed noise is still 30 uVrms, And DR is now 70 dB. Had there been a potentiometer before the final stage, that noise would have been reduced down to 3 uVrms, that's complete silence for most sensitive IEMs without anything playing, obviously you now have to take the fixed noise from the final stage in consideration.
What most do is to raised the output impedance so that the noise amplitude is greatly reduce with sensitive headphones, and yet there are cases where you can hear hiss from the thing.
A slight difference in volume and non proper sync can greatly change your perception, also knowing which device is which. Were you completely unaware of which device was playing in your blind test?
Have you tried to ABX the first mega link? That's a galaxy Ace driving a 80 Ohm load at 0.2 Vrms, why 0.2 Vrms? Because more clips the signal. THAT'S RIGHT, the **** can't even output more than 0.2 Vrms without clipping, that's a utterly terrible hardware in that phone and yet, I'm not able to ABX vs the original file.
