headchange4u
- Jan 3, 2005
I managed to get a free poker set a few weeks ago through work. The set consisted of some really nice poker chips, a couple of decks of playing card, and some dice. It also came in this really nice metal case. I immediatly had the idea that the poker case would make a great case for my iPod and accessories. It's big enough to carry my iPod, the wall charger, at least 2 small amps (my CMoy and Mint), extra batteries and any cables I might want to carry.
You can see a picture of a poker set very similar to the one I have here.
I also managed to pick up a piece of 1" foam from a radio box at work. Now I need to cut the foam so that my iPod and other accessories will have there own spot in the case.
I would like to know if you guys know the best way to cut out the foam. I would like to make this as neat and clean looking as possible, because I am anal like that. Since the case and the foam were free I also don't want to spend any money to buy some fancy foam cutting tool that I will probably never use again. Any tips or suggestion would be helpful
