cityle
- Apr 22, 2015
Disclaimer: I'm not reponsible for any damage done to your unit. Do it at your own risk.
The cable on the K553 was too long and too thick for my on-the-go use, so I decided to jump into my first attempt of a removable cable mod. (I had no experience before)
The audio jack I chose:
IMPORTANT POINTS TO NOTE:
- Wire the wires in the right way
On the audio jack: Gold: L+ Short silver: R+ Long silver: LR-
1. Set up your workspace with everything you will need (NB: usually with an iron, use a humid spong, I had none in this case so I used a humid towel)
2. Remove the left pads and unscrew the 5 screws.
3. Remove carefully the driver plate and unscrew the 2 screws that secure the plastic mount
(the thin black cable is the one that go on the other side, so don't damage it)
4. Cut the cable at the desired length (not too long or otherwise you will have problem to reclose the can. Maybe a little shorter than what I did)
5. Test fit your audio jack
Had to bend the long silver and rotate it for an ideal positionning.
6. Remove the sheath on the cable
You get 3 indivudual cables at the end and remove sheath from them too
7. Burn with a lighter the insulation fiber like material among the copper (hold the flame under the exposed cables for 3-4 sec)
8. Wire the wires to the audio jack (sorry for the bad focus)
9. Solder (Use flux while soldering. Unfortunately, I had none, so it was a little more difficult to solder correctly)
10. Test if the sound comes out
I had to remove more sheath from the main cable because I was not able to bend the 3 smaller wires
11. Position and screw the audio jack (I use some hot glue afterward in order to secure it even more)
12. Close the unit (here I hot glued a part of the cable on the upper piece in order to be easier to close it)
(the cables must run on the inside of the two plastic pieces on each side in order to be able to close it)
And here is the final result!
(I used some more hot glue outside because I didn't totally align correctly the audio jack correctly so there was a little gap)
