How NOT to clean your Model M keybord
post-197136
Thread Starter
Post #1 of 12
eric343
Member of the Trade: Audiogeek: The "E" in META42
Well, my precious Model M was feeling a bit greasy and dirty, so I figured it needed a clean... Now my spacebar, B, /, and M keys don't work!
Thank goodness for Windows' on-screen keyoard... but does anyone know how to open a Model M? The screws are REALLY hard to get at, and too tight to turn with pliers.
post-197346
Post #2 of 12
grinch
Cognac....icky.Scotch....icky.Vodka....
the way i clean my keyboard is take 90% isopropyl and put it on a tissue/chem wipe and rub each of the keys down. cleans stuff off quite well. isopropyl works for almost everything.
no idea how to open a model m though, sorry.
post-197373
Post #3 of 12
eric343
Well, I had to use a drill to widen the holes so I could fit the 3/16" socket in there to unscrew the bolts...
...only to find that the keyswitch mechanism and membrane are held between the black-plastic 'deck' (which is molded in such a way as to be spillproof - even including slots on the bottom that dump liquid directly onto your desk and keep it away from the switching bits) and the solid steel backing plate. Unfortunately for me, the deck is held to the backing plate with about thirty different "rivets" - plastic that has been melted to 'mushroom' the head, VERY securely and permanently clamping the deck and backing plate together.
Well, my server is currently keyboardless, needless to say. And time to call up a friend who collects tons of vintage computer stuff...
post-197406
Post #4 of 12
grinch
or you could just get a new one off ebay for $4.
post-197413
Post #5 of 12
eric343
SHH! The boards have eyes.
post-197424
Post #6 of 12
Flasken
Exhibit A in the case FOR a legal drinking age.
How I did it:
Used a knife to pop out all the keys - cleaned them individually. (this took almost 2 hours) Let them dry under a strong lightbulb (took two days)
popped them back in (after having carefully cleaning everything that was accesible with a toothbrush and a vacuumcleaner. )
For a while a handful of buttons didn't work (they didn't even do the click sound)
Now it's perfect (but I wouldn't do it again - I think the board gets damaged)
post-197453
Post #7 of 12
eric343
I popped off and cleaned the keycaps, then snapped them on (still wet) then rinsed the whole thing under the tap...
post-197469
Post #8 of 12
andrzejpw
May one day invent Bose-cancelling headphones.
lol, that's what people says works. Heck, I've heard of people putting them in dish washers!
post-197473
Post #9 of 12
eric343
I believe it - it really looks like it shouldn't be hurt by washing, but the fact remains that it's been almost 24hrs and the darn thing still doesn't work.
post-197490
Post #10 of 12
rickcr42
Are YOU talkin' to me?
you guys clean your keyboards ?
What a concept , gotta trythat one day !
edit ****notice the trythat was meant to be "try that" but the damn spacebar keeps sticking
post-197520
Post #11 of 12
andrzejpw
Hmmm, always been meaning to get an old Model M off of ebay. . .
Run a search on google. There are tons of websites devoted to that keyboard. I'm sure some have cleaning guides. Let me go look. . .
post-197521
Post #12 of 12
Flasken
eric:
In that case you might want to check if the buttons still are wet on the backside. Try taking out one that doesn't work and blow with your mouth on the back of it. If it's not dry you'll feel small drops of water against your lips.
If it is still wet I'd pop it out and make sure it dries completely.
