How much heat will it take to ruin my headphones?
post-7642020
Thread Starter
Post #1 of 6
Quote
The only hot place I leave my headphones is in the car while I'm out and about or something, but is that hot enough to damage them? Namely, the m50s and 840s.
post-7642043
Post #2 of 6
12345142
It probably won't damage them, although obviously you ought to avoid leaving your headphones to bake in the car as much as possible.
post-7642052
Post #3 of 6
PanamaRed
I've seen a car phone that warped from being left inside a hot car.
post-7642054
Post #4 of 6
sidel
You could definitely funky-up the plastic if it's getting enough direct sun.  I doubt you'll do any serious damage if you at least cover them with something though.
post-7645158
Post #5 of 6
erod
I use a RCA cable to hook up my iphone to my stereo in the car. First cable I used was a cheap RCA, the very first I found. That was a bad idea. The heat from the sun totally screwed up the cable, to the point where I could only hear music coming from one side of the car and also a lot of hissing. I bought a thicker, better quality RCA and it's worked great ever since.
Don't underestimate the heat inside a car. I would avoid leaving any kind of electronics in it on a sunny day.
post-7645219
Post #6 of 6
Adamora
but its a car phone! its supposed to be left in the car!
Bad QC!!
