Hey all
i'm considering buying some silver wire and making myself a silver cable for my headphones.
However, to save money I'm considering using silver wire for signal, and copper wire for ground.
Is this a good or bad idea? Is the quality of wire used in the ground very important, or does it simply have to be good enough to carry the signal away? I figure that it's important to carefully carry the signal TO the drivers (via silver wire), but once that's been done well, you can dump the signal any old way (copper). However, I'm also a little worried that using copper ground may cause some kind of bottleneck
Advice?
Advice?
