How dose Head-fi Rip their music?
Jan 31, 2011 at 8:18 PM Thread Starter Post #1 of 37
WhiteCrow
Is not fooled by rapper-endorsed products.
well I have yet to find a CD ripping program to use, and have been useing WMP, but it wont rip to flac, so I ask you, what do you guys use?
Jan 31, 2011 at 8:30 PM Post #3 of 37
dBpoweramp, because its the best. They give you a 30 day trial before it reverts to the free version, I'm not sure the difference because I use the paid version.
and follow their guide for secure ripping: http://www.dbpoweramp.com/cd-ripper-setup-guide.htm
Yep dBpoweramp for me too. The ripping is great and customizable and the batch converter is a lifesaver for those of us with ALAC libraries and FLAC-only portables
Jan 31, 2011 at 9:11 PM Post #4 of 37
lol ok thnaks guys I will look  into this.
Jan 31, 2011 at 10:06 PM Post #5 of 37
I begin by washing my fuzzy warbles on a VPI 16.5 using a 2 step process.
Then I place said vinyl back in its sleeve for a day or so to dry off.
I turn on the ADC and the phono stage.
I plug in the recorder. In my case I use an Iriver IHP120 on digital inputs
Then I put the vinyl on the platter.
I turn on the turtletable
I brush the record with a CF record brush
I brush the needle with a nylon brush
I begin the recording of the digital stream
I place the needle in the groove.
Done.
Jan 31, 2011 at 10:41 PM Post #6 of 37
well nice to see you have a fancy vinyl set up hahaha...also I just realized I said dose instead of does.
Feb 3, 2011 at 6:16 PM Post #8 of 37
some at head-fi will say EAC is best. Especially for scratched cd's. Personally, dBPoweramp is only used as a file format converter. I use EAC for my ripping.
Feb 4, 2011 at 11:06 AM Post #11 of 37
EAC for sure. Use the BlowFish guide to set up the program. It's really helpful to read the whole thing so you can understand why you need to use the setting the way the guide says. It will make you appreciate it more and be more comfortable in knowing you have bit perfect rips from your CDs. I just ripped 3 CDs as soon as I opened the package and I compared the FLAC files with the CDs on a Luxman D-08 player http://www.davidmichaelaudio.com/pc-394-4-luxman-d-08-cdsacd-music-player-dac.aspx and a Bel Canto DAC3.5VB http://www.davidmichaelaudio.com/pc-411-5-bel-canto-eone-dac35vb-dac-control-center.aspx. The sound was perfect with the FLAC file. The speakers I listened to were Harbeth Super HL5. http://www.davidmichaelaudio.com/pm-54-17-harbeth-super-hl-5.aspx
Feb 4, 2011 at 9:03 PM Post #12 of 37
used to use EAC, but dbpoweramp is just nicer to use and does cover art automatically ^_^
you know, wmp is probably just fine, too :)
Feb 5, 2011 at 11:28 AM Post #13 of 37
i use itunes in lossless, stored on an external hdd. good enough for me :)
Feb 5, 2011 at 11:50 AM Post #15 of 37
I use dbPowerAmp to rip to Apple Lossless.  I used EAC for a couple of years, but because I rip to ALAC, EAC isn't the best.  It uses iTunes to convert from WAV to ALAC.  dbPowerAmp uses Nero.  Nero is much less of a resource hog.  I still use EAC for the few discs that haven't ripped accurately in dbPowerAmp.  Unfortunately, most don't rip accurately with EAC either.  The big advantage of dbPowerAmp is the number of databases it looks up the disc on as opposed to EAC just looking in freedb.
