appar111
- Jun 4, 2002
I have a V5 Go-Vibe and wondered-- does an Elpac improve the sound quality further on this amp? I like the sound, just didn't know if power supply would improve the sound.
Originally Posted by IPodPJ /img/forum/go_quote.gif I'm still selling my 24V ELPAC. It improves the sound quality of the V5 and V6 by 200%. |
Originally Posted by Pete7 /img/forum/go_quote.gif talk about a sales pitch!!!!! |
Originally Posted by IPodPJ /img/forum/go_quote.gif It's not a sales pitch, Pete. I could care less one way or the other if I sell a $30 ELPAC adaptor. I'm not that hard up, even though I just spent a lot of money on an amp. ![]() The V6 was about a 150% improvement when used with the ELPAC 24V. I guess the AD8620/8610 opamps weren't quite as power hungry as the LM opamps, but they still benefit greatly from 24V. In fact, the differences were so great, I can't think of one listening session that I did not use the ELPAC 24V for. After hearing them with the 9V battery a few short times, I never used the 9V again. I don't travel, so why not have the best possible sound quality if I'm using them at home? I can't use it with the V7 since it was made to only work with 12V maximum. The 12V regulated adaptor with the V7 offers a 120% improvement over the 9V battery. The AD8397 opamps can run with higher voltage (up to 18V) I believe, but he made this amp to work with a maximum of 12V to accomoddate the charging circuit. He already had several models this time around, The V7 Eco, V7 Eco Extra, V7 Max, V7 Max Extra.... he just wanted to standardize a volt that would work with all of them, and the 12V regulated adaptor he supplied does. By the way, if you have your charging circuits active on the V5 or V6, you can not use the 24V adaptor. You must use the 12V regulated adaptor. The 24V ELPAC is for Go-Vibe V5 and V6 amps that have the charging circuit deactivated. The V7, charging circuit on or disable, you still need to use the 12V regulated. I hope that clears up some of the speculation. I spoke in great lengths with Norm about this. The V6m model, the one without the charging circuit, I personally named that amp the "V6m". He and I spoke about his amps on many occassions. And if someone can put me in touch with Jaben, I have a lot of high quality logos I designed for the Go-Vibe line that he can use, and that have gotten a positive response here at Head-Fi. |
Originally Posted by Pete7 /img/forum/go_quote.gif It's over-estimating. |
Originally Posted by nikongod /img/forum/go_quote.gif 2^(n-1) |
Originally Posted by IPodPJ /img/forum/go_quote.gif By the way, if you have your charging circuits active on the V5 or V6, you can not use the 24V adaptor. You must use the 12V regulated adaptor. The 24V ELPAC is for Go-Vibe V5 and V6 amps that have the charging circuit deactivated. The V7, charging circuit on or disable, you still need to use the 12V regulated. |
Originally Posted by appar111 /img/forum/go_quote.gif How can I tell if the V5 that I have has the charging circuit "activated"? And how can one "deactivate" it? |
