tigeruppercut7
- Feb 6, 2005
My shure e3c came with a little "pick" that's supposed to clean out earwax. I think the tip is a little too long and it might puncture the "audio membrane". Any suggestions?
Originally Posted by rogerlee Shure canalphones, I think, will seem to "break" after washing the earpieces sometimes and then magically start working after a few hours. I am pretty sure that the cause of this is water. If the earpieces aren't dry, then the water left in the stem region will be squeezed into the area with the driver, and on my left side, it always dies a little bit (sound becomes extremely muffled). After a few hours, the water evaporates, and hence, the "magical repair." |
Originally Posted by tigeruppercut7 My shure e3c came with a little "pick" that's supposed to clean out earwax. I think the tip is a little too long and it might puncture the "audio membrane". Any suggestions? |
Originally Posted by Zoide How are the Sensaphonics 2X-S supposed to be cleaned? Mine actually got more comfortable as they got more waxy, since they slip in and out muuuuch more easily. Still, now they look more opaque than transparent, and I'm just wondering.... |
Originally Posted by gorman Ouch, how gross! You are supposed to clean them regularly. The way you are doing it now, you are inviting ear infection to happen. Be carefule with you ears, they are the only listening istrument nature has given you. And they're not repairable. ![]() |
Originally Posted by rogerlee My tri-flanges get all icky yellow sometimes on the tips, and isopropyl alcohol does an okay job of cleaning it up. I usually just let it sit in alcohol, go do something for around ten minutes, come back, rinse them in water, and let them dry. Also, note the crucial step: LET THEM DRY! Shure canalphones, I think, will seem to "break" after washing the earpieces sometimes and then magically start working after a few hours. I am pretty sure that the cause of this is water. If the earpieces aren't dry, then the water left in the stem region will be squeezed into the area with the driver, and on my left side, it always dies a little bit (sound becomes extremely muffled). After a few hours, the water evaporates, and hence, the "magical repair." |
