Nak Man
- Aug 6, 2004
Oops, sorry to address you inappropriately. Ok, she. =)
• If you're not thinking to get any center speakers and surrounds then I believe you can still utilise 'dolby surround' receivers / avrs to watch movies. It would be allmost a waste to get DTS avr without good center channel (and surround) since that is DTS' real strength: discrete channels instead of simulated center and rear. For non DTS route you're in luck because you can get older model dolby surround AVR which usually still comes with turntable input (but you'd have to buy used). Many good options to choose: onkyo, denon etc with NAD and nakamichi being my favorite. Something from the mid 90s - not 20yr old as your technics (interestingly my 20yr old technics was also dying last year, model 555 or something, with 7 band equalizer =).
• However, if you intend to go all out on DTS and good center channel (almost a must), then get yourself a good DTS avr paired with external phono / turntable preamp. Ime these low priced phono preamps would sound just fine with no audible distortion or glaring flaw - I'm sure these won't be the bottleneck in your system. Stylus would play a bigger role on sound quality than phono preamp. I second lini's suggestion to spend the money on better stylus - but disagreed on his Yamaha idea =) Onkyo sounded much better to my ears.
Using both vintage receiver and DTS avr is workable but cumbersome. You can route phono out from vintage receiver to your new avr using tape pr record out. Btw it'd be difficult to find equalizer on current avrs, mostly have some kind of (useless) digital processing such as 'theater' 'hall' etc.
Edit : ugggh ... just read immtbiker kenwood specs. Latest DTS processing, 100w x 6, with phono input, for $229 ... unbelievable !!
Originally Posted by skylark However, if I would notice a difference in sound quality between a $40 pre-amp and a vintage stereo receiver, I'd prefer to buy a vintage just to use for the turntable and then an AVR as my primary receiver to take advantage of new technology. Nak_Man, now that my vintage receiver has failed and I have looked around, I admit I am very curious about all of the newer features, such as DTS. I've read about DTS in some online audio/video glossaries, and I'm hoping my older equipment might be able to take advantage of it and other technologies if powered by an AVR. (Also just FYI, I'm a "she," not a he. |
