castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I agree. @magicscreen refers to something real. it certainly is a rare occurrence for him in this subsection of the forum, but a valid argument doesn't depend on who's making it. This is not Tweeter. #scientificmethodman
It's not all that hard to find cables with relatively big differences in impedance that might lead, under certain circumstances, to noticeable sound difference.
For what @71 dB explained about impedance relations and resulting voltages(which is likely to be most cases of actual sound differences for amateur audio, beside someone messing up when soldering the pins), we can get a noticeable amount of variation in amplitude of the overall gain or just at some frequencies. By that logic, cables can indeed make a difference.
Obviously any half decent listening test would match levels before starting, and remove a bunch of cases from the table. But we already have established over the years that it is an insurmountable standard for this community. So we're stuck. They only experience BS conditions and do mistake volume differences for about anything but what they are. IMO, not clearly acknowledging the potential volume difference, is only reinforcing their beliefs that something else in the sound(that can't be measured or similar silliness) is causing their impressions.
When it comes to impedance affecting sound, instead of looking for the most out of spec cable and not even knowing how, I rely on secret ancient artifacts long forgotten by the modern audiophile civilization. Mystic tools such as "the volume knob!" and "the equalizer!". But that's me, I always do weird revolutionary stuff like measuring a few variables for the cables I purchase to make sure I got what I paid for. I admit it, I'm a bad boy.
One exception I always bring up is for some IEMs with stupidly low impedance where I would look into voltage divider or just adding resistors in series(which could count as part of the cable I guess...). Because damping is going to suck anyway, and the extra resistance might save the amp section. I did that fairly often some years back. Now I just stay clear of those IEMs that are stupid-loads™, and my nomad life is exponentially easier and more enjoyable as a result. But again, weird IEMs exist, they can be popular and many have been FOTM(I have an hypothesis about audiophiles being on the M side of SM). Swapping cables on those IEMs is likely to actually be audible. To me swapping cables is backward thinking(unless the original cable had some known defect), and not the best solution, but with some luck it could look like one solution.
