castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I honestly cannot figure out a legitimate reason why silver would have a sound. All else considered equal(which is a fantasy in the world of audio cables), we gain some 6% in resistance of one wire on its own in a straight line. Cool, I guess. for the rest, copper and silver are so very close as conductor they mostly stick together no matter the type of signal or temperature involved, at least for audio stuff and temperature we can survive in.
I would feel lucky if half of those 6% variation remained with actual cables plugged into a system(arrangement of the wires, insulation, soldering, plugs, contact surface between plugs, how stable the cross section remains throughout the wires). And I would be a little impressed if in practice, the metal in the wire was indeed the main electrical difference between 2 given cables. I mean, the tolerances for audio cable impedance(when they even bother having some) are commonly in the 10 to 20%.
But somehow people try 2 cables, one copper, one silver, often from a different brand and sometimes not even with the same gauge. They feel a change, and go: Eureka! It's the sound of silver.
jumping to conclusion with a classic correlation=causation fallacy, isn't ideal.
On the other hand, you're jogging in the park at night and you come face to face with a werewolf, you're going to feel silly with your copper IEM cable. So, good arguments for both sides? Ahoooo!
