How do I balance headphones when Windows 10 offers no left/right control
Jun 5, 2020 at 12:10 PM Thread Starter Post #1 of 21
gilkinted
UK
The question says it all, really. I am listening through Dragonfly Black/DT 770 Pro 250 ohm and need to adjust lefr/right balance on the phones. There is no visible balance option on the Windows 10 sound control panel dedicated to the Audio Quest dac. What to do?
Jun 5, 2020 at 2:33 PM Post #3 of 21
gilkinted
UK
Give this a try good fellow:
Thing is - as per screenshot and as mentioned in question - there is no visible balance option in my version :slight_frown:
Jun 5, 2020 at 2:42 PM Post #4 of 21
fastfwd
Silicon Valley
Some devices have it, some don't. Dragonfly Red/Black -- and maybe the other models -- don't.
Seems as though AQ could expose the balance controls with a firmware update, but posts have been made here about the issue since at least 2016, so I'm not holding my breath.
Jun 5, 2020 at 2:48 PM Post #5 of 21
gilkinted
UK
Ahhh! So this is dependant on the driver supplied by the device mfg, not Windows. I see now why I couldn't force Windows to provide it (its available through the GPU audio output). As you say, if AQ have been asked historically, don't suppose it's at the top of their list for upgrades. However, I will formally ask them Thanks for that info.
Jun 5, 2020 at 7:15 PM Post #7 of 21
fastfwd
Silicon Valley
No, @NA Blur, that doesn't work for the Dragonfly. It will work fine for built-in audio, but it won't even adjust the DF's volume, let alone its balance.
Jun 6, 2020 at 6:26 AM Post #9 of 21
gilkinted
UK
Thanks @NA Blur (and others) I appreciate your efforts! Turns out this is a common if minor problem with no simple answers. I did contact AQ's UK rep and many thanks to Nick Allen who immediately replied to my query. It seems "unfortunately due to the DragonFly’s design, there is no option of balance control". I thought I'd post that response here for info. I could try a small amount of cotton wool in my left ear :triportsad:
Jun 7, 2020 at 7:20 AM Post #12 of 21
gilkinted
UK
Reluctant to strap anything on to the end of the audio chain which is: Hi Res streaming from PC/ Dragonfly Black on usb port/ MF X-Can V2/ DT770 pro 250 ohm. It just happens that the X-Can (like the majority of headphone amps) has no balance control. I did briefly install Equalizer APO but Windows 10 objected to it taking control of Audio enhancements.If I can't effect a balance change at source i'll give up and revert to modest amounts of cotton wool :triportsad:
Jun 7, 2020 at 8:06 AM Post #13 of 21
GREQ
Frankfurt am Main
How so? It should be a fairly straight forward install.
Jun 7, 2020 at 11:01 AM Post #14 of 21
gilkinted
UK
Well - I re-installed Equalizer AOP and this time no objection from Windows. However apart from the old chestnut of what appears to be left/right outputs swapped somewhere in the PC chain, or at least the interface shows them to be (I know the music presents correctly at the headphones from familiar instrument placement) I discovered that I have something approaching 6db deficiency in my right near! Anybody want to buy some hifi? Seriously thoiugh, its probably particular frequencies that are affected and I'd be eq-ing until I'm blue in the face to level those out. So.. thanks for introducing me to these solutions but I've decided to live with it. Just to say as a newbie to the forum it is brilliantly well informed and contributors helpful and thoughtful. I'll be sticking with Head-fi, that is certain. Cheers.
Allan
Jun 7, 2020 at 11:08 AM Post #15 of 21
davesa
Do you not have this in your Windows 10 Audio device settings? I do.
Go here and select Device Properties:
