How Charging gumstick battery for 1 st time
Jul 26, 2003 at 8:09 AM Thread Starter Post #1 of 10
Silver
I am charging the 9WM gumsticks that included with the D777. It stopped charging after a hour. But then I pressed the charge button again and it charged for another 20min-ish until it stopped... Should I keep doing that until it has been charged for 8 hours or just stop now? Thanks.
Jul 26, 2003 at 8:19 AM Post #2 of 10
Just stop now. Play your D777 to discharge the battery fully, and then re-charge the batteries again. Most NiMH rechargeable batteries are shipped partially charged.
Jul 26, 2003 at 8:29 AM Post #3 of 10
so far as I know the D777 knows when the batteries are fully charged (if you press charge after they've had a full charge, you'll see the light blink twice, and then shut off) - I'd hazard a guess that it'd be okay to double charge once, but I wouldn't personally make a habit out of it as it would shorten the battery life
Jul 26, 2003 at 9:01 AM Post #4 of 10
Haha... So the shop instructed me to ***** up the battery(they told me to do so), it could be their bad since if the battery screwed up they had to gimme 14WMs for free
Jul 26, 2003 at 12:15 PM Post #6 of 10
Did you run it until it was completely flat? - if so how long did it last (bearing in mind that if you use ESP that that uses twice as much battery bower as without it)
Thanks
Jul 26, 2003 at 12:54 PM Post #7 of 10
Thanks
It had been running it for two hours until it was completely flat...
Jul 26, 2003 at 6:34 PM Post #8 of 10
Without looking at the instruction manual I can't remember exactly, but iirc the total time before charge should be between 3-4 hours... try charging a couple more times... seeming if the usable time settles down... if not, then I think you'll have a valid reason for getting those 14WMs...
Jul 27, 2003 at 6:27 AM Post #9 of 10
I have just taken a look at the Japanese manual of my 777, it says that with the gumstick battery the battery should last for 5 hours without ESP... Is that true? If so, my gumstick is fine since this time the 777 has been playing for about 3 hours since its last charge...
Jul 27, 2003 at 7:33 AM Post #10 of 10
That does sound about right to me...
I guess that it has to be remembered that if this player is NOS / NIB that the batteries will have been sitting idle for the best part of eight years... I daresay that they needed some encouragement to wake up
Either way... glad that they're holding out for you now... and am also glad that you're liking the D777
...Enjoy
