BowerR64
- Aug 23, 2004
The membrane is really thin, a drill isnt going to work. I think it will just rip it. Its pretty thin. You could use a metal nail and heat it up with a lighter. You can do the hole any way you like, this was the easiest way for me.
I tried several ways, i have about 12 pair of eggos. First i tried them with the cups off. They didnt seem to sound as good as with the cups on. The cups add the midrange that i like from the eggos. One set i put a pea size hole in, the other set a smaller hole, then i got a set from some one on this site who ripped the membrane completly out. The pea sized hole had the best sound, bigger isnt better, and smaller restricts the air.
What you could do is carefuly remove the membrane and try some other way to plug the 1" hole the membrane covers and just try different size holes. Use model plastic glue to glue the membrane back in for the stock sound.
Originally Posted by warubozu Bower, When you make the hole in the membrane, is it possible to carefully use a drill to make the hole instead of a soldering iron? The reason I ask is that I currently don't have a soldering iron. Can the membrane itself be removed from the ear cups? |
Originally Posted by Tucker "WIth headphones i found it to be the oposite" Don't most people say that closed headphones have more bass and less soundstage? That's the general rule right? With the Grados, they have no room behind the speakers at all if they're sealed airtight, so that makes sense to me it would radically change the sound. Still though, I find it difficult to see why a pea sized hole would be needed. Doesn't the DT77o have like a couple milimeter sized hole, and isn't the pea sized hole by volume maybe 10x as large? So if it's just airflow, wouldn't a pencil lead sized hole work for the D66? Not trying to be a jerk, just curious. Also, how was your graph of the D66 pre/post mod generated? |
