finleyville
- Nov 30, 2001
I wanted to know if anyone could help me with a home networking problem that has me stumped. I know just enough about computer networking to be dangerous. So please respond in small words. Heehee
I have a notebook running Windows 98se I want to connect to my desktop running Windows XP. I configured the desktop (DT) to be the host and the notebook (NB) to connect using the Windows XP cd. I have an Ethernet card in each and am using a crossover CAT-5 cable between the two.
The problem is that the two computers do not see each other while hooked up. Yet when I unplug or shut down the NB I receive a notification on the DT that a network cable has been disconnected. So at least the hardware notices that something is going on. The frustrating part is that in the past it did work, sortof. Sometimes they would see each other, and sometimes only one would see the other but not the other way around. Weird.
The workgroups are spelled exactly the same. I have file and printer sharing selected on both computers. I even specifically set both hard drives to “sharing.”
I asked a local computer retailer if they could help. They responded that a router with a built in switch like the Linksys unit was the way to go to solve my problem. But I since found out that I still would have to run the Windows XP cd on the notebook. But if it doesn’t work now using a simpler direct connection then I don’t see how adding components would help.
Anybody have some advice?
