Home-Made IEMs
Jun 9, 2021 at 4:15 AM Post #12,886 of 12,896
dnspics
Are you sure this isn’t just a bad seal?
No bad seal!
If I connect the microphone directly to the iPad everything works.
Jun 9, 2021 at 5:06 AM Post #12,889 of 12,896
dnspics
I have no idea why that would be the case. What type of mic/adc do you use?
I use an Umik-1 with its built in USB adc and I don’t have such problems.
An China 711 with 3,5 jack. I have ordert an external USB soundcard.
I think I once read that the internal MacBook sound cards have pop protection on the microphone. But I can no longer find the article.
Jun 9, 2021 at 11:22 AM Post #12,891 of 12,896
Aldo40
mont de marsan
Hi, I now have my measurement microphone with 711 and am trying to measure my IEMs with REW on my MacBook Pro.
Now I have the problem that the MacBook behaves strangely because the low frequencies are not displayed correctly. All IEMs look the same at the bottom. On my iPad the microphone works without any problem. Is there a setting on the Mac that I can't find for the 3.5mm TRRS connector?6E11749B-E5C6-44E5-BEEC-5B41F09E736A.jpeg
it is as if the software was set to 200hz, check this
Jun 9, 2021 at 6:17 PM Post #12,893 of 12,896
kkugel
Switzerland
Jun 10, 2021 at 4:07 PM Post #12,895 of 12,896
dnspics
No need for external soundcard, use apple 3.5mm dongle, super accurate
Hello,
Thanks to everyone who helped me!
The problem is really the headphone input of my 2015 MacBookPro, which has a pop suppression, where I have not found how to turn it off, but I do not care now.
The solution is now the 3.5mm USB-C dongle from Apple which works great and is not expensive.
Now the experimenting can start :wink:
Jun 10, 2021 at 11:12 PM Post #12,896 of 12,896
mattmatt
Glad things worked out!
Hello,
  • Top
