I'm very confused at this moment with all this components because I believe they can worsen the sound quality if I do something wrong .
Imagine i can fit 2 x 38D1XJ00 , 1 x 2389D and 1 x EST65QB02 in soundlinks shell which is medium size shell.
It depends the skills .
first of all
https://www.audioholics.com/loudspeaker-design/crossovers
all you read about crossover and crossover damaging the sound is 90% hoax
if you can adjust phase and impedance
crossover have a huge advantage
a ceramic capacitor wont worsen the sound
neither a metal film resistor
the 10% truth about crossover damaging the sound quality is wasted energy in heat from these component
or capacitor peizo effect
bro, we have technically done everything here in this thread
and a properly designed system offers way less IMD(to the level of none), way better transient and impulse and the only con is just very minute signal lost on component, which can be compensated with increasing the volume
plus, resistor, inductor and caps behave as linear instead of non linear devices
i can go on and on.
components dont make sound worse, its the application
