Choy Wei De
- May 16, 2017
wow for me it's very good bro, i also modified the base shell kz zs3
I bought this driver quite sometime back from Taobao. Does anyone know what is the green thing on the soldering pad?
AFAIK 99% of the time its an enamel coating to
1. Electrically isolate it, and
2. As a visual indicator (many sellers will refuse exchange/return if you've soldered the unit)
You can use nail polish for a similar effect. 1% of the time its just a swipe with a marker just for indicator/looks.
Do I need a special method remove the coating? Or do I just solder over it?
That is what I said to him on pm.Just solder over it. It's insulating paint or something. Or you can sand it off.
By the way...after a long time
@Xymordos
And one more thing.
Note: FED30048 and TinAudio P1 or the 10mm planar sound the same.
The planar just have the planar style super speed bass and rising treble response above 10kHz.
Note: I will be making some set on the name of my friends here. Something like a tribute set like what I did for my Mom (modified @Furco GQ+ RAB)
Starting with @Choy Wei De
GQ30783 + GQ30710(3dB attenuation)(replacing RAB32033 in MASM)
It will be the simplest 4 way crossover design lol
Let's see, how it turns out
Me too...just got some spare time todayI'm always around just don't have time to build any new ones yet
Yes, that could be it. What do you think of the rest of the curve compared to MASM3? (because of the air leak I have no listening test yet)Wavelength of 13khz in air is approx 2.6cm. Could that be a resonant frequency of your measurement setup?
