Senor CIEM
- Mar 8, 2017
Hi!
Maybe someone can help:
Knowles GV - 4 vents, 2 are covered with 1 yellow tape, the other two with a "black" tape - If all vents are OPEN (tape removed) I should get better bass response, right? Is this working in a closed shell? You guys open the vents or you mean it makes not much difference? I tried it, but to me it's not a huge one.
Shell finish with Fotoplast Lack:
Final finish with the Fotoplast is a bit hard if you want it perfect (100% perfect), I always get very tiny "bubbles" not a lot, just a few on the surface after it has been hardened in the UV light. Any ideas about getting a super and perfect finish? Maybe changing to the Egger Lack instead? Or do you guys buff the shell a bit (to remove tiny bubbles and irregularities and then polish it to high gloss? Any suggestions welcome!
And final question:
Glue the tube to the BA. Best practise? Did it always with fotoplast gel and hardened it, but if the tube gets too much bend in the shell, the tube is getting really easy of the BA. superglue should not be the way to go I read. Any"professional" suggestion?
Thanks a lot!
And final question:
Thanks a lot!
