Home-Made IEMs
- Thread starter Bilavideo
For how long did you cure the Resin and what kind of lamp did you use?
aratj
about 40 sec.For how long did you cure the Resin and what kind of lamp did you use?
use
https://ru.aliexpress.com/store/pro...108.1000016.1.1e74a966MJY4D9&isOrigTitle=true
aussietanker
I am quite curious to know how well that LED lamp cures the mix. How do you find it? Does it cure "all the way through"?
1. I have been saving to get a "professional" grade curing lamp from somewhere like Oaktree products, but they are several 100 dollars as opposed to $22 ... Is it worth spending the extra to get the professional grade UV light? Does it make any difference over a simple one like this? I would really appreciate the advice of ppl who have used both, especially those that have upgraded to one of the 'professional' grade units... and those that have only used simpler LED units like this one. Is there any significant difference in the outcome?
2. Also, most of the nail curing lights seem to have buttons for 15, 30, 60 second operation. Is not being able to select a specific and precise time an issue?
3. And the required wavelength is > wavelength is 360nm > 405nm. Is that correction?
4. Is higher wattage better?
Appreciate the response
Hello! First post here.
I'm sorry if this has been asked before, but how would one go about replicating JH audio's freqphase?
Also, any tips on wiring a crossover?
I want to try to build a Layla clone.
Also, does the layla use two SWFKs up top or TWFKs?
And, the filters are green for the low and mid, none for the top correct?
Thanks!
Thanks!
Pete64
- Apr 30, 2016
Happy New Year all you Headfiers!
I just recieved my pair of GV-32830. I thought it was the black dots to be removed for increased bass? Im confused as the other side has two holes also that is covered with some tape. Anyone knows for sure about this, i really dont want to tamper any more than i have to with those babies
Pete64
- Apr 30, 2016
Using Shilos (which is a good one) or any others recipie for gel
I got a good tip for anyone that (like me) get a lot of microbubbles in gel when reheating, if you did’nt already know.
Alcohol is tha crap to get rid of bubbles! When it’s heated just spray some kind of alcohol over the surface, it does’nt take much.
I used an aftershave bottle first time, that i did’nt like alot anyway and just one spray made them all go away like pure magic.
Rgds
Pete
Rgds
Pete
aratj
Puggie
- Jan 23, 2009
Epic thread and some awesome work here. I'd like to have a play with a basic/simple BA build, something along the lines of etymotic or finals designs, a single driver bullet type of IEM. What BA drivers should I be looking at for as full range as a single driver can be?
Many thanks
Many thanks
aratj
etymotic ER-4S / P / B - Knowles ED-29689
Im1fan2nv
Can anyone help me with the preparation/process for making a faceplate out of wood? Do I coat the entire piece with foto then attach it with foto? My friend said he would like a satin finish that is stained. Would this cause an issue with attachment to the shell?
Thanks
Thanks
ForceMajeure
- Jan 19, 2014
Just a thought, but you could make a thin faceplate out of resin and glue the wood on that acrylic plate with super glue or gorilla glue. Then attach that plate to the shell using the resin as usual...after that you are free to sand it and curve it so it blends with the shell almost seamlessly.Can anyone help me with the preparation/process for making a faceplate out of wood? Do I coat the entire piece with foto then attach it with foto? My friend said he would like a satin finish that is stained. Would this cause an issue with attachment to the shell?
Thanks
Regarding the lacquer coating, you'll need to lacquer at least after the joint part and use a different buffing and/or lacquering technique for the wood if you want a satin finish. I bet a few guys here have other ideas.
aratj
Rabid86
- Jan 25, 2015
Hello guys! I am back with some news about the progress. It has not turned out that great with the electronic filter. I have tried many different combinations of capacitor values and resistor values to make the best notch-filter.
When I tried different combinations on a breadboard, I found a great combination of a highpass-filter and a lowpass-filter. They work great independently! But combining them to make the notch-filter function is not working, no matter what I try...
I can only hear the lowpass-filter working, the high frequencies are not coming through at all.
So what exactly is the problem here? I have made a diagram of how I have connected these aswell as taken a picture of how it looks.
I know it is very crappily made, but it is just to try it out to see that it is even working. But since it is not working, I want to be able to know exactly where the problem lies.
Did I connect something in a bad way? Did I use the wrong components? Or did I miss something?
I tried using cheramic capacitors before, but they sucked away a huge part of the volume, it was barely any sound left.
Any suggestions are more than welcome!
Thank you!
/Anders
Thank you!
/Anders
Dulalala
- Jun 18, 2016
Thank you!
/Anders
Why is there a three way parallel between the resistor, capacitor and transducer?
Total: 16 (members: 0, guests: 16)
