Home-Made IEMs
469 470 471 472 473 474 475 476 477 478
480 481 482 483 484 485 486 487 488 489
  1. CCX191
    alanwcruz, Mogol, Einencool and 6 others like this.
  2. sanekn
    Sweet job, mate! :)
    I've also made a pair some days ago...
  3. ForceMajeure
    any of you guys that want to make alcohol inks and are in the US... hum Shilo hmm humm...check out that deal on amazon https://www.amazon.com/dp/B0717B6VVB/?m=ATVPDKIKX0DER
    currently 30usd for 72sharpies (of course you don't need that much but it's a good deal and you have a greater range of optional colors)
    making alcohol inks is rather easy. there are a few guides on youtube. basically you need alcohol, a few bottles and some sharpies...it is way cheaper than buying the regular and you have great quality alcohol ink.
    Im1fan2nv likes this.
  4. BigBublik
    Please rate the quality of the casts. Was doing the first time.
    And please draw lines as i need to cut it.
    [​IMG]
    [​IMG]
  5. sanekn
    Hello, seems not enough matter on the stomp of the impression. However the canal part looks great to me.
    But waiting for specialists to answer :)
  6. ForceMajeure
    pictures lack other angles. you should be ok though
    if you don't want to take a risk cutting the bottoms. cut roughly the extra part from the side and sand the bottom of each impressions so you have the same height on each. sand one then sand the other and check the height. then you should be able to make small adjustments on the go.
    another cut I wasn't able to show is the cymba part.
    it should look like that after you cut it and shape it
  7. AndrewOkie
    What do you think about my impressions? https://imgur.com/a/9l73o Im not sure how to cut cymba part. By the way, did I mark out the excess material correctly?
  8. ForceMajeure
    They look ok, you could use them as is if they are comfortable to you. you could get away without cutting that part necessarily. although you have to take into consideration that this is where the connector will sit and how they will feel with a cable attached...f.e the further they are, the bigger the loop with the cable will be if you will.
    personally I would shape that part to be slightly "straighter" with the dremel but I wouldn't cut it (this is a drastic procedure at that stage that I wouldn't do). you don't want to change too much in there as you already have a nice place as where the connector will sit.
  9. Einencool
    Hi Guys,
    I‘ve got a question about some Bluetooth cable Adapter.
    I‘ve got a Adapter with some cheap earbuds. I‘ll cut the Earbuds and would like to take the cable for my GK or GV IEM. But I‘ve the Problem, that the Volume is much to high for the CIEM. On Level 1 of 15 on the iPhone it is very loud. So I would like to put a resistor into the cable of the Adapter, but I don‘t have a idea, where to start with it. And because I must buy them Online, I‘d like to know, which resistors I should buy and what a wattage they should be...
    Thank you in advance, and I‘m looking forward for Shilos Guide :)
    Greets Chris
  10. buffect
    I am making silicone custom earphones.
    and my works.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    It's a wireless bluetooth silicone iem.
    [​IMG]
    [​IMG]
    This video is for wireless silicone custom earphone.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The one at the center is the hybrid. 1dd + 1ba
    [​IMG]
    [​IMG]
    CoiL, Mogol, Im1fan2nv and 10 others like this.
  11. buffect
  12. buffect
    Do you want to make it like this?
    [​IMG]
    [​IMG]
    cjxj and JorgePantalones like this.
  13. BigBublik
    What silicone are you using?
  14. Shilohsjustice
    Hey guys and gals, I have been working on the tutorial as well as been working a busy schedule. I hope to have it done over the next couple weeks.
    Stay tuned.
    aussietanker, Bassiklee and MuZo2 like this.
  15. faiwinnie
    want to know more pls
