Hello Guys I´m here again.
I managed to do the Gelatin+glycerine negatives as described by Shilohsjustice. They have good consistency and it can be melted again to try again, in case the first try wasn´t successful. I´ve also been playing with the drivers I ordered to see how they would combine in frequency and phase, I think I got the right combination of tube lengths and polarity.
About the tubes, I went to a medical supply store and found FEEDING TUBE gauge 8FR (15 in long used for adult) and gauge 5 (35 in long used for infant). The gauge 5 fits perfect in the dirvers port and it fits inside the gauge 8 tube. The dampers fit a little tight in the gauge 8 tube, but if you stretch it out a little, they will fit with a little struggle. Each tube was about 50 cents of a dollar (8 Mexican Pesos).
I just got the EGGER UV resin last week after a loooooong international shipping time but I haven´t bought the UV nail lamp because I´m not sure what wavelenght is necessary to cure the EGGER UV. Does any of you have information if it has to be a specific wavelenght? or it can be any uv light and the only thing to look for is the curing time?
Thanks everyone!
I have made my own Egger EL1 unit
and use following instruction to work with EGGER LP/H (transparent):
- Fill the LP/H or LP/HS material into the negative mold made of duplicating
material (REF 40900 ff). Make sure that the negative mold is completely
filled and bubble free. - Cover it with black foil (REF 53200 or REF 53100).
- Put the filled negative mold into the UV-polymerization unit and let it
polymerize according to the following polymerization times. Gas ow is not required if you work with the UV-polymerization unit EL 1 plus N2.
EL1: 2 min. 30 sec. to 3 min.
ATTENTION: The mentioned polymerization times are guide values, they may vary depending on the s
- Remove the black foil after polymerization.
- Pour the liquid material into a container that is impervious to light.
This material can be reused. - After having completely poured out the liquid material, put the negative
mold and the blank but without the black foil into the UV-polymerization unit again. We recommend placing ITE shells in the unit with the opening facing downward. Gas ow is not required if you work with the UV-polymerization unit EL 1 plus N2.
EL1: 1 min. to 2 min.
- Take the blank out of the negative mold and put it into a transparent container (REF 50107) lled with LP-Cleaner (REF 31300 ff). Then put it into a UV-polymerization unit for the second polymerization.
