Holo Audio Spring R2R DAC
Sep 15, 2017 at 11:38 AM Post #1,471 of 4,062
I'm hoping I won't feel compelled to buy an SU-1 as I would really prefer not to add yet another box and signal cable between the NAA and DAC, as well as another power cable. In fact, I would really like to de-clutter!
I am not a fan of Holo's USB implementation. When I first took delivery of my Spring, I tried using it via "straight USB". I wasn't impressed. I put an Intona in the USB signal path and things improved. ...but nothing beat the SU-1 and the I2S connection.
I feel that the Holo Spring is a very good DAC "out of the box". However, you can really get it to punch over its weight class with an SU-1.
Sep 16, 2017 at 6:36 AM Post #1,473 of 4,062
I'm about to pull the trigger on the Spring L3, but i still have a few doubts though.
I understand its USB input is the worst of all in terms of SQ, too bad this is the one I'm going to use.
I just invested an arm and a leg on a SOtM trio (sMS-200ultra, tX-USBultra and sPS-500) to improve the USB signal being fed to the DAC.
Do you think this will work good with the Spring L3?
Or am I wasting my money?
I am using my KTE Holo Spring L3 using usb.....I am enjoying it so much, that I have not really even thought about the SU-1 much.
I may get it after I get another set of headphones that I want, just to compare for myself. I have no issues with usb at all, never had a drop out with this dac.
Sep 16, 2017 at 12:24 PM Post #1,474 of 4,062
My Spring KTE 3 arrived before the SU-1, so I was able to compare microRendu>USB>Spring with microRendu>USB>SU-1>I2S>Spring. With SU-1 it sounded a bit better to me, overall more clarity, lack of upper range hash, very clean transients. Yesterday I started comparing USB>SU-1>I2S to USB>Eitr>S/PDIF and I so far I've not heard much difference.
Sep 16, 2017 at 1:28 PM Post #1,475 of 4,062
When you use the I2S input on your Holo Spring you're bypassing the internal AK4118A receiver circuit and pretty much sending the signal straight to the digital/analog converter. Taking one more conversion step out of the signal path is where many owners perceive an improvement.
In my experiences/testing - I've found the I2S to be the preferred input. The differences were subtle, but in back-to-back testing; clearly audible.
Sep 16, 2017 at 1:52 PM Post #1,476 of 4,062
But with the SU-1, you are not removing any conversion from the signal path: what was done by the AK4118A within the Spring is now done by a comparable chip within the SU-1.
Sep 16, 2017 at 2:45 PM Post #1,477 of 4,062
Power cords ideas anyone?
Without going bankrupt?
Depending on your definition of going bankrupt: Anticables Level 3 or Ice Age Audio Silver/Silver
Sep 16, 2017 at 11:43 PM Post #1,478 of 4,062
The AntiCables level 1 seem well built and within my stretched budget.
Not sure I understand the difference with Level 3 but I guess they are a good starting point.
Consider that my Liquid Carbon came with an Audioquest NRG X3 which is probably at a similar level with the AntiCables L1?
Sep 17, 2017 at 6:35 AM Post #1,479 of 4,062
I only have experience with them L3 so I can't comment on the L1.
Honestly I'd give Ice Age Audio a try. It was only marginally bested by the Level 3 and its 1/3 the price. I did a comparison between those two and the Emotiva XIEC. I would have kept the Ice Age Audio cable but I went into the the comparison telling the manufacturers that I would keep which everyone was best regardless of price. Rick at Ice Age Audio is a good guy. When I decide to finish upgrading the rest of my power cords I'm going there.
http://www.iceageaudio.com/audiophile-power-cords.html
Sep 17, 2017 at 6:53 AM Post #1,480 of 4,062
Thanks for the hint, I will give the SILVER/SILVER a try (that's the one you tested right?)
Sep 17, 2017 at 7:52 AM Post #1,481 of 4,062
Sep 17, 2017 at 10:09 AM Post #1,482 of 4,062
Just got my Holo Spring on Friday and hooked it up today. Needed an emergency make-shelf as I was running outta room on my table. This Holo Spring is by Wildism Audio in Hong Kong. It has its own "Wild Stage Special Edition" (it's own Level 3 I guess). I opted out of the AudioNote Trans-280 Pure Silver Digital Transformer to save a little bit of $$$ as that's for AES use only and I don't use AES.
Right now, it's USB driven with the iFI Audio iUSB Micro 3.0 (on the right side of the Electra).
Sep 17, 2017 at 10:18 AM Post #1,483 of 4,062
Anyone using Holo Spring on a home audio stereo setup (no headphones- just speakers)? With Amp, and speakers?
If so, which preamp do you use for Volume control?
Sep 17, 2017 at 12:03 PM Post #1,485 of 4,062
I am using Allnic Audio T-2000 25th AN, KT150 tube base Intergrated Amp which put out 100 watts pure tube music to Kef LS50;Blade2,Himsound A33,Impress and DIY speaker using morel tweeter,5 inch Focal Mid,Two 8 inch Focal Woofer with HMDF cabinet among them I rotate speakers for my feeling. My previous DAC was PS audio PW MK2 and SS PRE,POWER amp.I also have Aurender N100h 4TB, Intona together with First KTE 3 unit I have since last September. I like spring more THAN DAVE for DSD sound for my speaker system. and also ordering Mivera Audio Music server,Streamer, DAC for hopely upgrade from holo spring I will keep both.
  • Back
