Holo Audio Spring R2R DAC
post-14521330
Post #1,876 of 2,090
earnmyturns
SF Bay Area
SF Bay Area
Does the Hd800S pair well with the holospring?
You need to specify the amp to get any useful feedback. I don't have those headphones, but in my experience, the DAC-amp pairing makes a big difference on how different headphones perform. I have a Holo Spring KTE 3. With a solid-state Neurochrome HP-1, MrSpeakers Æon Closed sound very balanced and dynamic. With a hybrid tube-solid state Schiit Lyr 3 with a high-end tube, Æon Closed sounds constricted and somewhat disjointed between lows and mids. OTOH, MrSpeakers Ether C Flow sound glorious with the Lyr 3. Same DAC, different amps, very different outcomes depending on headphones.
Reactions: Liu Junyuan
post-14530105
Post #1,877 of 2,090
nick77
I have a modded Singxer SU-1 to allow connection to Spring i2s. Kitsune DC conversion. Big leap in performance going i2s.
Send me a pm if interested.
Reactions: alphanumerix1
post-14644101
Post #1,878 of 2,090
hyperdanny
the new version Holo Spring 2 is now on sale both on Kitsune (for US) and Magna (for Europe).
The list of improvements is long but somewhat vaguely worded..better resistors (actual % not said), a "femtoclock" and more, what's very clear is that there's a marked (at least for Europe) increase in prices..basically the version 3 is 300 euros more!
post-14644475
Post #1,879 of 2,090
Whitigir
Ok, I am In for dsd1024 .... however, what in the heck can do Digital to Digital conversion that output DSD1024 via I2S ?
People only think DAC is important....the DDC is also just as important.
The compensation is something similar to AudioGD has been doing for a while, sadly...no DSD1024. I heard the Kitsune HS once in comparison to r2r7. Back then, the R2R7 had issues with it Firmware which is now much improved over a few versions of firmware. I heard the negativities of Brass Pins in HS and then I went to research on it and was so sure there were everywhere. Hope this is fixed ? I worked on my r2r7 and it brought a huge improvements
I also would love to know the Clock system on the HS2, what is it
post-14649984
Post #1,880 of 2,090
aleksander85
Slovenija
Slovenija
Does anyone have new Holo Audio - Spring II DAC Level 2 (R2R - DSD1024) ?
I,m considering this one or Audio GD R8..?
What do you guys think would be better option and why?
And one more question..what do you benefit when using Singxer SU-1 usb?I've seen this device in some youtube videos and i dont know what is it for..?Is that for streaming and for using i2s connection or am i wrong?
thx for helping me.
Reactions: HoloSpice
post-14653159
Post #1,881 of 2,090
Whitigir
thx for helping me.
SU-1 is a digital to digital conversion.
What does it convert ? Well, it take in USB signals, and convert it into I2S signals whatever the USB signals may contain (PCM, DSD...etc..)
What is the I2S signals ? I thought DAC only take USB in ? Well, I2S signals is a processed and separate timed clock signals, it is called Inter-IC Sound (IIS). Your IC chips AKA DAC-chip is communicate by this Signals. Then what about the USB in on the DAC ? Exactly this, in digital world, you need digital interface (USB, Coax, AES, IIS...etc..). USB is just one of the input on the DAC, but whatever input it takes in, it would need to have an according interfaces to interprete this incoming digital signal into IIS signals. So, in short, your USB input in the DAC is simply USB-Digital to Digital Conversion. It will become IIS before it get to your DAC.
So why do we use DDC (digital to digital conversion) ? Well, because more than often, the USB within your DAC is poorly implemented with only acceptable clock oscilliators and or power supply. The SU-1 is a dedicated DDC. It has separated ground isolation, linear power supply with ultra low noises, and other features to improve the sound quality for your digital files
post-14654999
Post #1,882 of 2,090
aleksander85
Slovenija
Slovenija
Thx for that..i think i understand much better now.
So in this case with SU-1 and I2S conection we should always get some inpruvement in sound..
And Singxer SU-6 is same thing but ''new and inpruved one''?
But is this meaningful only when used for streaming (roon,Tidal...) or even when used when playing (Flac ,..) from SSDdisc?
ty
post-14655035
Post #1,883 of 2,090
Whitigir
ty
Yes, you will get improvement due to better clock precision’s and better power supply from your DDC
Yes, SU-6 is a further improved DDC based on SU-1 but is using the same DSP Chip (digital Signal Processing) which is XMOS XU208
It is meaningful whenever you are sending Digital signals into your DAC. Therefore, Roon, Tidal, YouTube, DSD, PCM of all kinds Wav/Flac...etc....Yes, even files stored on SSD
post-14655061
Post #1,884 of 2,090
aleksander85
Slovenija
Slovenija
Thanks my friend.
Did you heared new holo spring II?And is there big diference (soundwise)betwen 2 and Kitsune version?
post-14655064
Post #1,885 of 2,090
Whitigir
Thanks my friend.
I wish I could afford them all to answer you :D, but I don’t :wink:
I am curious about the II as well.
post-14655071
Post #1,886 of 2,090
aleksander85
Slovenija
Slovenija
Yea i understand..I also have tu safe money 1/2 year to buy somethink like that.Puting together my HI-FI sistem for 6-7 years and now hunting for new DAC(had M2tech Young before).
I,m mostly listening to records and that is the sound that i want from my DAC(or as close to that).
post-14655092
Post #1,887 of 2,090
Whitigir
I need more info about the II, but so far, I can’t find detailed pictures or specs out there. Pretty sad though
post-14667727
Post #1,889 of 2,090
topgunsphd
Anyone have any experience with the spring 2? Is the USB better now to where DDC, like singxer su1, is no longer needed for better sound?
post-14670246
Post #1,890 of 2,090
aisnikkor
Took a chance and ordered the KTE Spring 2 this past week. Still 3+ weeks out on delivery.
I was set on getting a level 1 original Spring, and the KTE SU1, but when I finally was ready to order, the Spring 2 was up on the Kitsune page. Given you need at least level 2 of the Spring 2 to get the remote (which will be useful to me), I was now looking at the upper level models rather than level 1. With the current sale going on, decided to go all in for the KTE Spring 2 together with the KTE SU1.
Improvements that pique my interest with the Spring 2 are the remote, that additional detail is now being shown on the display, and that the I2S input is supposedly improved over the original. Also of interest is that the KTE model now officially has hand selected DAC modules.
My worries are that the DAC module is a refined design over the original Spring - will it still perform to the same high level? Power supply has been changed a bit as well. Feedback from Tim at Kitsune and some trust that the designer would not go backwards in performance goals gave me enough confidence to go forward with the purchase.
I’ve scoured the internet every couple of days for the past two weeks, and to date no review info is posted anywhere yet on the Spring 2 that I can find. Used google translate quite a bit these past few weeks...
Anxiously awaiting both feedback from users, and delivery of my new DAC. So hard to be patient :).
