RhisorHier
- Jul 8, 2015
Here's the setup. ASUS Xonar DX and Yamaha RX-V571 connected via the speaker out on the Xonar to RCA inputs on the Yamaha. I'm using a cheap, probably not shielded 3.5mm to RCA cable. It's on of those black cables that you get with equipment for free.
When I'm on the desktop or playing a video or music, there is no noise. It's clean. The moment I start up a game, especially the new COD BO4, I get signal noise. The sound is high pitched and will raise in volume if the game doesn't make a sound. New sounds negate the noise and it starts up the process of going from quiet to loud. During gameplay it isn't a problem because there's new sounds all the time.
The sound only exists when connected to my receiver. I've connected my ATH-A700's directly and there is absolutely no noise. I like to run my headphones through the receiver as an amp for my cans. I have Beyerdynamic DT-770 pro 250ohms that I like to use.
So my question is how do I resolve this noise? Upgrade my cable? Add ferrite chokes to some existing wiring? Thank you ahead of time!
