High end (IEM) cable thread: impressions, pics, comparisons and reviews.
Nov 3, 2016 at 12:09 PM Post #256 of 4,052
Rei87
You can use a balanced CABLE, on BOTH balanced and single end out. Best outcome, you get sound from both, e.g. the Lotoo Paw Gold takes 3.5 TRRS in its single end too. At worst, you dont get sound from one side.
however, never, never use a single end cable, on a balanced socket. You could, and most probably will, fry the circuits.
Nov 3, 2016 at 11:46 PM Post #257 of 4,052
chaiyuta
Bangkok, Thailand
  Yes but this is something different altogether :wink: If I understood correctly, he's just asking what happens if you plug a balanced cable in a single ended output.
Sorry about my typo. I just amended it. In case 3.5mm balanced cable + earphones plug into 3.5mm SE output of DAPs or Smartphones, Does it make my earphones broken?
Thanks all you guys for answering my question. Since some says OK some says NO, I will avoid plugging inappropriate jacks in.
Nov 4, 2016 at 1:58 AM Post #259 of 4,052
jmills8
Previously known as bmiamihk
Hong Kong and Miami
hello
which cable pair with se5way ult the best? Its on the way.and I'm consider pairing with a ak240.
thanks
Listen to the 5way for a month and sense if you prefer more treble or more sub bass or you just want a wider soundstage.
Nov 11, 2016 at 11:16 PM Post #263 of 4,052
chaiyuta
Bangkok, Thailand
ironpeg : Thanks, It's a nice review. How long of revision cycle of ARES and EROS series? For example, since EROS I released till EROS II released, how long does it take to launch a new revision one?
Nov 12, 2016 at 12:41 PM Post #265 of 4,052
  I wasn't the one reviewing that :p
For the question, please ask Eric @EffectAudio
Heyy, thank you for your interest in EffectAudio's brand's product and development :)
We rarely would do revision to our product line up. Eros, Ares, Thor silver has been in the market for years before making a revision. Unless we discover a major breakthrough in technology, geometry, materials and etc, we will not revise our current product line up.
-Eric
https://www.facebook.com/effectaudiosg/ https://twitter.com/EffectAudio https://www.instagram.com/effectaudio/ http://www.effectaudio.com/ info@effectaudio.com
Nov 13, 2016 at 12:51 AM Post #266 of 4,052
tim0chan
Hi, can I get a recommendation for a cable for the aaw w500? It has a warm and thick signature. I would like something to tighten the bass and shove the mids forward.
Thanks in advance
Nov 15, 2016 at 5:21 AM Post #270 of 4,052
tim0chan
No problem. The Twag is more analytic and cleaner, the neptune warmer and more musical. They should both widen the mids significantly and tighten and control the bass.
I'm deciding between a second hand silver widow and the twag, which would be a better match. There's also the dilemma of a black Friday sale on the twau
