rojik
- Aug 23, 2015
Would this dac/amp do for the DT990 premium 600 ohm?
http://hifimediy.com/DACs/spdif-dac-230V
You could skip the DAC and go with the Schiit Magni 2. It would probably do a reasonable job.
Why are you stuck on the DT990 600 ohm if you can't afford to spend some on the DAC/amp? Why not go with the DT990 250 ohm? I don't think there is anyone on Head-Fi that would recommend the 600 ohm version if you can't afford the electronics to go with it.
Then your best bet if your budget is limited is to skip the DAC for now and buy a more powerful amp. Better to drive them properly. Buy a separate DAC one day in the future when you can afford it if you still feel like you need it.
What is your overall budget?
Doubtful, given it has 2V rms listed for the headphone output.
This is why many people go with the DT990 250 ohm. The 600 ohm are more expensive AND you need to be prepared to spend some money on a DAC/headphone amp setup. If <$100 is all you can manage for a DAC/headphone amp for the DT990, you should focus on the 250 ohm version and use the extra money to get a better DAC/amp for them.
