HiFiMan Susvara
Jun 7, 2019 at 2:40 AM Post #2,551 of 11,894
Johnny1982xyz
Italy
Jun 7, 2019 at 5:01 AM Post #2,553 of 11,894
fredfung28
Hong Kong
Just saved $9k lol
I don’t just look on measurements but I really try it to see if that makes an improvement or not. I’m not using entreq but tripoint signature, if your country could have a home trial I do recommend to try it.
It’s all about the real listening rather than using some threads to ignore what it could do.
I trust my ear rather than just read what someone said
Jun 7, 2019 at 5:04 AM Post #2,554 of 11,894
tunes
New York
Did you do a blind with and without comparison?
Jun 7, 2019 at 5:06 AM Post #2,555 of 11,894
fredfung28
Hong Kong
Yes, on Tripoint yes. Ab and blind also.
Tripoint is a bit different than entreq, it’s not using rock and mineral. I don’t know theory behind though
Jun 7, 2019 at 5:21 AM Post #2,556 of 11,894
tunes
New York
i have both the 1266 TC and the susvara and am using the formula s /powerman combo with both.....the amp is fantastic with both and the best i have heard with planars...what i love is the amp is made for HP's unlike speaker amps and do not overpower the HP which i find gives them a relaxing yet powerful presentation...highly recommended
Passlabs XA25 Looks like a great amp in speaker application reviews but gets very hot to touch like a tube amp. The price compares well with the dedicated HP amps as well. Any compare this amp with Susvara to XI Formula S/powerman?
Jun 7, 2019 at 5:34 AM Post #2,557 of 11,894
tunes
New York
What's worse, is that those $9,000 Entreq grounding boxes are just wooden boxes full of rocks! Ones you can get for pennies on ebay or Aliexpress & like two thin cheap bent copper plates that also sell for just cents.
There is a cheap speaker terminal connector drilled into the wood & that's it.
Someone of whatsbestforum accidentally cut the cover on his expensive Entreq USB cable, only to find out that underneath the cotton sheath, was a plain generic $1 USB cable.
Someone should try this with headphones.
“I want to state that I do believe in creating a star ground system for your components. Ampex Roger on our forum motivated me to try this for my system. I don't need an African Bubinga wooden enclosure with laser engraved metal plates on the top and front of the box though. I just used a chunk of copper bus bar with some holes drilled and tapped for screws and ran a 10 gauge wire from each of my components to the bus bar and connected them with spade lugs to the bus bar. I ran one ground wire from the bus bar to the center screw of the outlet where my preamp is plugged in. My noise floor has never been lower and I'm quite happy with this arrangement. It's not as sexy looking as a polished Bubinga box with "classified" parts, but it does a damn fine job.”
Jun 7, 2019 at 7:42 AM Post #2,558 of 11,894
fredfung28
Hong Kong
btw I have a question, as 2.5mm plug had no lock system, using heavy headphone cable like prion4 or other more heavier one, will it fall from the headphone?
Thanks!
Jun 7, 2019 at 7:59 AM Post #2,559 of 11,894
Slim1970
STL
Thanks!
No, it doesn’t fall out. But I do hear the music cut out briefly when I move my head on occasion. So it does lose contact momentarily.
Jun 7, 2019 at 1:11 PM Post #2,560 of 11,894
bozebuttons
Co-organized 1st International HF Meet (NY 2006)
Godfather of Babylon
ARC REF75 is a tube amp so I would not recommended that. At least some resistance on the taps is required.
I ran my K1000s directly off my Conrad Johnson premier 12 140 watt tube monoblocks with no issues
Jun 7, 2019 at 4:05 PM Post #2,562 of 11,894
cladane
France
Question for people running speaker taps, does your cable go straight from headphone to speaker taps or do you use a balanced xlr adapter in between? Thanks
For me directly from speakers tabs to headphones.
About 2.5mm connectors, the cable doesn’t fall out since those from DHC clip well.
Ground boxes effect is very relative to your home electrical conditions. It is like power regenerators. These must be tested in your personal setup.
Jun 8, 2019 at 9:09 AM Post #2,563 of 11,894
bozebuttons
I use A stephanaudio (K1000)equinox balanced 4 pin xlr to spade connectors(amp side), .
Jun 8, 2019 at 8:42 PM Post #2,564 of 11,894
Whitigir
This is actually science too! Music and it frequencies are noises...not just a simple sinuous waves as people would imagine but they are by itself “noises”. It can only make senses when people hear noises and take it as music :)
Jun 9, 2019 at 7:46 AM Post #2,565 of 11,894
MeetYourMaker
America
Having tried/owned numerous TOTL headamps, The auris nirvana is a pretty terrible pairing with the Susvara, relatively speaking . Congested , linear sounding and lacks dynamics and control
There are headphone amps and speaker amps that are a far better match . If youre looking for an amp for the Susvara you can do a lot better, even at a much lower asking price.
If you think its great then so be it, we all hear things differently. But IMO, the Susvara is far more capable than you think if you find the Nirvana to be 'great'
just wonderwing, have you listened to any other speaker amps since the 700i?
