junki
This is an update: Dekoni actually sent out the correct pair of pads free of charge, so now I'm listening with the Dekoni TH-900 Elite Hybrids.I wanted to give an update to my journey looking for after market pads now that I've arrived at my destination...
These pads are very, very similar to Sundara's stock pads, which I've figured out are the HIFIMAN PaliPads. They are more or less exactly the same in all dimensions, and the way the ear cavity walls are perforated are largely the same. The differences are:
- The velour on the Dekoni is the typical sort of slightly fuzzy velour you'd expect on most velour pads. The PaliPad uses a sort of mechanically woven, not-fuzzy-at-all mesh. The PaliPad's mesh looks more premium, but the Dekoni velour is oh-so-soft and better feeling on the skin.
- The PaliPad has protein leather outer and perforated protein leather inner, while the Dekoni uses real lambskin both outside and along the inner ear cavity wall.
- The PaliPad uses some sort of regular foam that deforms gradually over use. The Dekoni uses memory foam that much better molds to my face, earlobe, and glasses.
With the felt-tape-modded ZMF Universe pads, the sound was very close to the stock sound, but the deeper ear cavity did make the sound a tad more closed with a tad less microdynamics than with the PaliPad. But with the Dekoni TH900 Elite Hybrids, I literally cannot hear a difference compared to the stock PaliPads. To my ears, they are sonically identical.
However, due to the memory foam, the softer velour, and real lambskin, the Dekoni is more comfortable and higher quality. There you have it: the Dekoni TH-900 Elite Hybrids are my highest recommended aftermarket pads for the Sundara if you want to preserve the Sundara's stock sound while making your ears happier!
