Hifiman Sundara (HE400i upgraded, around $500)
Jun 4, 2021 at 7:32 AM Post #3,466 of 3,469
DagsJT
Over the past few months I’ve had X2HR’s, 58X’s, Meze 99 Classics and in the last week I got the Sundara’s. For me, only the 99’s had less clamp than the Sundara’s. The X2HR’s and 58X’s clamp FAR more for me.
I was thinking of picking up this cable:
https://www.amazon.co.uk/dp/B07M5Y4...olid=25GKMUJNFJCQA&psc=1&ref_=lv_ov_lig_dp_it
It also mentions TRSS but I think I read elsewhere that it should be fine on the Sundara as the extra point wouldn’t be used anyway?
Jun 4, 2021 at 9:08 AM Post #3,467 of 3,469
theMUKe
I would strongly assume that these work. Otherwise you could go with https://www.amazon.co.uk/gp/aw/d/B08L33999M
It mentions the Sundara in description. For some reason it's a bit more expensive.
Jun 4, 2021 at 10:54 AM Post #3,468 of 3,469
DagsJT
Yep, that’s the one I initially had in my basket. But then I did a bit more digging, found the other cables and am curious why they’re quite a bit cheaper.
I figure I’ll get the cheaper cable and if it doesn’t work then I’ll just return it.
Edit: I messaged the seller on Amazon asking if the cheaper cable would work with the Sundara and they replied saying the more expensive one is needed.
