bagwell359
Thanks, I spent months trying to get the settings set - but also not mangling the sound too much. I'll flip you my settings for the v1, very close. The higher ringing area: 9k +/- 800 Hz does shift from unit to unit. You'd have to take time with yours to dial it in exactly.Thanks for thatI've just put those exact settings in and it's now better. I only use an eq when it's essential, and so now that's a lot less deviation than a full shelf. Great stuff 👍
Ringing has a pernicious effect but after mods like "fuzzor" and pads, there is music present as well, so you can only shave off a smidge to make it easier to listen too but not rob the music of its overtones. I wrote maybe a dozen pieces on this topic in the main 500, OG 6, and 6 SE threads if you get into it.
